Home » Language IDEs » C / C++ IDE (CDT) » Hello World! <terminated, exit value: -1073741515>
Hello World! <terminated, exit value: -1073741515> [message #876966] Fri, 25 May 2012 15:54 Go to next message
Casper Mathisen is currently offline Casper MathisenFriend
It works fine when I run it manually, but when i run it directly from eclipse i get that error, and it doesn't output "Hello World" in the console. Any idea what might be wrong?
Re: Hello World! <terminated, exit value: -1073741515> [message #876972 is a reply to message #876966] Fri, 25 May 2012 16:04 Go to previous message
The problem seems to be caused by misleading information at help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Fconcepts%2Fcdt_c_before_you_begin.htm...
You do have to add MinGW to your PATH.
Previous Topic:gdb pretty printing
Next Topic:How to compile a VisualDSP project in eclipse ?
Current Time: Sat May 26 08:23:38 GMT 2018
Powered by FUDForum. Page generated in 0.01697 seconds
