Home » Eclipse Projects » Gemini » Installing gemini-blueprint-1.0.0.RELEASE(Problems installing gemini-blueprint-1.0.0.RELEASE with Eclipse)
Installing gemini-blueprint-1.0.0.RELEASE [message #876562] Thu, 24 May 2012 20:49 Go to next message
Cameron Ross is currently offline Cameron RossFriend
Are there any instructions for installing gemini-blueprint-1.0.0.RELEASE? I'm having problems installing it in the dropins folder within eclipse-jee-juno-M7-win32-x86_64. Note that I'm also using spring-framework-3.1.1.RELEASE.
Cameron.
Re: Installing gemini-blueprint-1.0.0.RELEASE [message #876727 is a reply to message #876562] Fri, 25 May 2012 07:46 Go to previous message
Glyn Normington is currently offline Glyn NormingtonFriend
Using Gemini Blueprint is a bit of a DIY affair of installing its three bundles and their dependencies. Presumably you've read the documentation? See also the OSGi Enterprise spec for general information on the Blueprint standard.
Note that Gemini Blueprint 1.0.0.RELEASE does not work with Spring 3.1.x - see bug 375225.
Previous Topic:Gemini Naming 1.0.0.RELEASE is now available
Next Topic:Gemini DBAccess 1.1.0 M1
Current Time: Sat May 26 16:05:21 GMT 2018
Powered by FUDForum. Page generated in 0.01774 seconds
