Home » Modeling » TMF (Xtext) » Xtend, rich strings and SEPARATOR option
Xtend, rich strings and SEPARATOR option [message #876315] Thu, 24 May 2012 11:05 Go to next message
Aran A is currently offline Aran AFriend
Member
In a previous post I have seen this code with rich strings
toString(Entity e) '''
«e.name»
«FOR member: e.members BEFORE "(" SEPARATOR "," AFTER ")"»
«member.toString»
«ENDFOR»
The result will be the members separated by commas, in parentheses. If there
are no members, there won't be parentheses.
OK, but how can I do if I have a conditional inside the FOR?, as in the example:
«e.name»
«IF (a condition...)»«member.toString»«ENDIF»
«ENDFOR»
Then, the result could be something like: m1, , , , m5, m6, m7, , , , , , m13,
How can I do if I want a result will be m1, m5, m6, m7, m3 ? Do I have to work it by hand?
Thanks in advance,
Aran
Re: Xtend, rich strings and SEPARATOR option [message #876379 is a reply to message #876315] Thu, 24 May 2012 13:36 Go to previous message
Christian Dietrich is currently online Christian DietrichFriend
What about wrapping it into an extra extension using map and filter?
e.g.
«e.name»
«FOR member: e.members.filter(m|a condition) BEFORE "(" SEPARATOR "," AFTER ")"»
«member.toString»
«ENDFOR»
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Thu, 24 May 2012 18:08]
Report message to a moderator
Previous Topic:J2SE-1.7 Problem
Next Topic:greedy option in xtext
Current Time: Mon Jun 18 13:57:52 GMT 2018
Powered by FUDForum. Page generated in 0.02093 seconds
