| Trouble Deploying on Tomcat 6 on CentOS (XML parsing error Exception) [message #875318] |
Tue, 22 May 2012 10:16  |
bret lester Messages: 2 Registered: May 2012 |
Junior Member |
Hello, I downloaded the 3.7.2 runtime, copied the WebViewerExample to the webapps directory, and renamed it to Birt as described in the eclipse wiki.
However it is not working. When I browse to /Birt, the only thing I see is this "XML parsing error on file /WEB-INF/web.xml" exception (full stack trace below). The funny thing is, after I refresh the page a few times i get a different exception (also below). It may be random.
Any information on how to fix this issue would be greatly appreciated. Thanks for your help!
Here's the 1st stacktrace. This one always comes up the first time i browse to /Birt:
org.apache.jasper.JasperException: org.apache.jasper.JasperException: XML parsing error on file /WEB-INF/web.xml
org.apache.jasper.compiler.JspConfig.processWebDotXml(JspConfig.java:207)
org.apache.jasper.compiler.JspConfig.init(JspConfig.java:222)
org.apache.jasper.compiler.JspConfig.findJspProperty(JspConfig.java:277)
org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:112)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:332)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:312)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:299)
org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:589)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:317)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
root cause
org.apache.jasper.xmlparser.ParserUtils.parseXMLDocument(ParserUtils.java:98)
org.apache.jasper.compiler.JspConfig.processWebDotXml(JspConfig.java:91)
root cause
javax.xml.parsers.ParserConfigurationException: expand-entity-references
gnu.xml.dom.DomDocumentBuilderFactory.setParameter(libgcj.so.10)
gnu.xml.dom.DomDocumentBuilderFactory.newDocumentBuilder(libgcj.so.10)
org.apache.jasper.xmlparser.ParserUtils.parseXMLDocument(ParserUtils.java:93)
And the second stacktrace, which appears randomly after a few page refreshes:
exception
org.apache.jasper.JasperException: org.apache.jasper.JasperException: Unable to load class for JSP
org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:156)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:329)
root cause
org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:623)
org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:144)
root cause
java.lang.ClassNotFoundException: org.apache.jsp.index_jsp not found in org.apache.jasper.servlet.JasperLoader{urls=[file:/usr/share/tomcat6/work/Catalina/localhost/Birt/], parent=WebappClassLoader
delegate: false
repositories:
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader{urls=[file:/usr/share/java/tomcat6/,file:/usr/share/java/tomcat6/tomcat-i18n-fr-6.0.24.jar,file:/usr/share/java/tomcat6-el-2.1-api-6.0.24.jar,file:/usr/share/java/tomcat6/catalina-tribes-6.0.24.jar,file:/usr/share/java/ecj-3.4.2.jar,file:/usr/share/java/tomcat6/jasper-6.0.24.jar,file:/usr/share/tomcat6/bin/tomcat-juli-6.0.24.jar,file:/usr/share/java/tomcat6/tomcat-i18n-es-6.0.24.jar,file:/usr/share/java/tomcat6/catalina-6.0.24.jar,file:/usr/share/java/tomcat6/jasper-el-6.0.24.jar,file:/usr/share/java/tomcat6/catalina-ant-6.0.24.jar,file:/usr/share/java/jakarta-commons-pool-1.3.jar,file:/usr/share/java/tomcat6/tomcat-i18n-ja-6.0.24.jar,file:/usr/share/java/tomcat6/tomcat-coyote-6.0.24.jar,file:/usr/share/java/mx4j/mx4j-remote-3.0.1.jar,file:/usr/share/java/tomcat6/annotations-api-6.0.24.jar,file:/usr/share/java/jakarta-commons-dbcp-1.2.1.jar,file:/usr/share/java/jakarta-commons-collections-3.2.1.jar,file:/usr/share/java/tomcat6/catalina-ha-6.0.24.jar,file:/usr/share/java/tomcat6-jsp-2.1-api-6.0.24.jar,file:/usr/share/java/log4j-1.2.14.jar,file:/usr/share/java/tomcat6-servlet-2.5-api-6.0.24.jar,file:/usr/share/java/mx4j/mx4j-jmx-3.0.1.jar], parent=gnu.gcj.runtime.SystemClassLoader{urls=[file:./,file:/usr/share/tomcat6/bin/bootstrap.jar,file:/usr/share/tomcat6/bin/tomcat-juli.jar,file:/usr/share/java/commons-daemon.jar], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}}
java.net.URLClassLoader.findClass(libgcj.so.10)
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:134)
org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:66)
org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:621)
FUDForum. Page generated in 0.01495 seconds
