| Eclipse skipping breakpoints [message #874737] |
Mon, 21 May 2012 09:13  |
Ido Missing name Messages: 6 Registered: December 2009 |
Junior Member |
My issue isn't a new one, and I found several threads about it, yet no one was helpful for me. I hope this one will.
I can't debug with eclipse. It recognizes breakpoints, switches to debug prespective, but somehow it gets out of sync and I can't debug my code. It seems to stop at the right class but I see no green line and I can't use F5 and F6. Sometimes It works, but after a while it happens again. There is no exception or error.
I work with JDK 1.6.0_24, Glassfish 3.1, eclipse INDIGO (but it also happens on HELIOS too).
I tried (as I found on the web) to set eclipse to use Parallel GC. I tried put it in the eclipse.ini file, I tried to put in the glassfish VM arguments itself, and I tried to put it at eclipse JDK additional VM arguments (preference -> installed JRE-> JDK -> etc). Nothing seem to work for me. I also tried them all together.
Help me please..
Thank you all from advance,
Ido
[Updated on: Mon, 21 May 2012 09:20] Report message to a moderator
| Re: Eclipse skipping breakpoints [message #875733 is a reply to message #875404] |
Wed, 23 May 2012 04:49   |
Junior Member |
OK, I noticed few more things:
1. On the Debug view, in my stck trace, I found the exact class with the breakpoint is paused and it had this comment: "(Suspended breakpoint at line XX)". When I clicked the line, suddenly the green line appeared. Yet, as soon as I clicked F6 to continue, It went out of sync again, just the next line became suspended. Weird.
2. I checked the processes running on my computer and found that there are several "java.exe" processes running at the same time. (eclipse runs on javaw.exe). Maybe this is why glassfish and eclipse refuse to work together.
3. I checked the build path and found that this is my output folder:
project-name/target/classes. Is this good?
I didn't mention that I use maven, if it matters.
Any thoughts?
Ido
[Updated on: Wed, 23 May 2012 05:01] Report message to a moderator
FUDForum. Page generated in 0.01680 seconds
