Home » Newcomers » Newcomers » Importing project from SVN unable to run project on localhost?(Run requires server port # number change?)
icon5.gif  Importing project from SVN unable to run project on localhost? [message #872686] Wed, 16 May 2012 15:43 Go to next message
ch_arles M is currently offline ch_arles MFriend
I'm new to setting up eclipse, but not new to using the it. I'm having problems and hope someone can help me. I don't have the professional support otherwise.
I'm trying to run an existing project on local machine. I am using Tomcat 7.x. I took the following steps:
File -> Import -> SVN -> Checkout projects from SVN
Select the "use existing repository location: radio button
Select the URL to repository
Click Next
Select folder in repository
Requires a Login, I log in
Select "Checkout as a project in the workspace" radio button
Click Finish
Project opens in Eclipse
Click on the .jsp file in the WEB-INF folder I want to view
Start Tomcat (port 8080)
Click Run
I get the error (attached screenshot) telling me there are "several ports (8080, 8009)
etc., required by tomcat v7.0 server at localhost are already in use. ...
Can someone tell me how to fix this?
I tried closing a project I had open in Project Explorer, guessing that was the problem -- Select the project -> File -> close project. However I got another error message saying the "resource <projectName> is not accessible for launching"
I don't want to launch that project. I want to close it or remove it from the Project Explorer window and launch the project I imported from SVN.
How is this done?
Thanks!!
Re: Importing project from SVN unable to run project on localhost? [message #872747 is a reply to message #872686] Wed, 16 May 2012 18:29 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 5/16/2012 9:43 AM, ch_arles M wrote:
> [snip]
> etc., required by tomcat v7.0 server at localhost are already in use. ..."
> I tried closing a project I had open in Project Explorer, guessing that was the problem -- Select the project -> File -> close project. However I got another error message saying the "resource<projectName> is not accessible for launching"
> How is this done?
> Thanks!!
It's not that you have another project running. It's that Tomcat's
running on your box already (or something else) on port 8080). You'll
have to change the port the Tomcat under Eclipse's control is running
on. Go to the Server view, usually bottom center of the workbench, and
double-click your Tomcat server. A page will open in the Editor view
allowing you to change what ports are used.
Re: Importing project from SVN unable to run project on localhost? [message #872784 is a reply to message #872747] Wed, 16 May 2012 20:17 Go to previous messageGo to next message
Thanks, Russell. I changed the port to 8000, however, I still can't launch the page. I'm getting a different error. "The selection cannot be launched, and ther are no recent launches." What step/s am I missing or doing wrong? Thanks.
Re: Importing project from SVN unable to run project on localhost? [message #872796 is a reply to message #872784] Wed, 16 May 2012 20:41 Go to previous messageGo to next message
For me, this post is asking two questions, the first about importing
projects that are in Subversion and the second, the real one I think you
wish to address. They are pretty much unrelated, I think.
In a Dynamic Web Project projects that builds correctly (and this
question really belongs on the Eclipse web tools forum), you right-click
on your JSP, thing.jsp, and choose Run As -> Run on Server. Typically,
this launches the internal (Eclipse) browser.
However, there are a number of things you need to set up in the
workspace that weren't a function of importing this project from
Subversion. I assumed you'd already set them up. These are:
- Integrate Tomcat into Eclipse workspace.
- Create a server "project". Add the project you wish to run to it.
This is covered in a number of tutorials. Mine is here, but it's very
basic and verbose, so you'll have to pick your way through what's not
relevant to your more advanced state:
http://www.javahotchocolate.com/wtp-tutorials/wtp-tutorial.html
Re: Importing project from SVN unable to run project on localhost? [message #872864 is a reply to message #872796] Thu, 17 May 2012 01:11 Go to previous messageGo to next message
Thanks, Russell. I looked over your tutorial, and I know I will be going through it more closely very soon. Thank you for writing and posting it.
As I've given the steps that I have taken to check out the repository in Eclipse, I won't type that again.
Here's the thing, I need to edit some JSPs, save them, test them in the browser and keep them version controlled. Taking my steps above however, didn't allow me to edit the project at all, only view it in a seemingly "read only" state in Eclipse. I have integrated tomcat 7. I installed Subclipse.
Since I am obviously going about this wrong, my question is how do I access a project (that is in a SVN repository) in Eclipse via Subclipse, edit a page, and then run the page using tomcat so that I can see it in a browser? Then save my changes back in SVN. I don't know how to do this. I hope this clears up what I am asking. Thanks.
Re: Importing project from SVN unable to run project on localhost? [message #872867 is a reply to message #872796] Thu, 17 May 2012 01:21 Go to previous messageGo to next message
Russell Bateman wrote on Wed, 16 May 2012 16:41
Subversion
Hmmm, I didn't create a server project initially. I tried a few different things, so I don't remember what I did exactly. I did set up a separate workspace for my project and imported the files from the project in SVN into it. My steps are getting too convoluted. I need to start all over again. So the first step is:
Create a server "project". Add the project you wish to run to it.(from SVN) correct?
Re: Importing project from SVN unable to run project on localhost? [message #872872 is a reply to message #872867] Thu, 17 May 2012 01:39 Go to previous messageGo to next message
I tried creating a new project and importing project from svn into the newly created project
I tried directly importing the project by selecting FILE -->"import" --> create a new project by checking out an existing project from a SVN repository"
Neither of these methods will show the project in the "Add and Remove Projects" dialog box for tomcat to run it.
As I said, I'm obviously going about this all wrong because nothing I'm doing is working, but I keep trying different things based on stuff I'm reading via google or trying to find a logical path. Perhaps I should stop until someone gives me a step by step process about how this done, I really can't believe it's as difficult as it has become for me.
Re: Importing project from SVN unable to run project on localhost? [message #873090 is a reply to message #872872] Thu, 17 May 2012 13:25 Go to previous messageGo to next message
> repository"
I don't use Subversion any more--or rarely--but I've never set up my
projects the way you've described. Doubtless you can do that, but I
haven't. I use Git, but other than the version control tool, I do what
I'm describing here. It appears from the .png you posted that you're on
Windows 7, so I'll tailor my remarks. (I use Linux almost exclusively,
but what I'm saying here, I've done hundreds of times on Windows.)
Set up an Eclipse workspace to host this project. This would include a)
Eclipse IDE for Java EE Developers, b) a Sun JDK (and not merely a JRE)
and c) Tomcat. (a) through (c) are of course covered in that tutorial.
You're probably already okay here.
Set up TortoiseSVN (if you haven't/don't know how to, see:
http://www.javahotchocolate.com/tutorials/tortoisesvn.html).
Bring the Subversion-controlled sources into your filesystem where you'd
like them. Make sure they "work" the way you'd expect. I don't use
Eclipse-Subversion integration to do this. I never have. This is where
our methods diverge. There are other forums, like the Eclipse technology
Subversive one, that might recommend a more "space-age" and integrated
approach; I'm just telling you what works and has always worked every
time for me.
Assuming the source code is there...
If what's in Subversion is in fact a proper and correct Eclipse project,
the import them into Eclipse via File -> Import -> General -> Existing
Projects into Workspace -> Next and Browse to the parent of your
project's root, select (don't double-click) on that project, then click
OK. This should display projects Eclipse thinks are there. Select the
one(s) you wish to import and click Finish to do it. Incidentally, I
would NOT "Copy projects into workspace" (Eclipse offers this).
If, however, what's in Subversion isn't a proper/well formed Eclipse
project (maybe its author screwed up committing the necessary files),
then you'll have to create a new project.
Do this via File -> New -> Project... -> Dynamic Web Project and, when
the wizard comes up, type in the project name, then unclick Use default
location. Browse to your project's root, click OK and proceed. Again, if
offered, don't let Eclipse copy the project sources into your workspace.
Hope this doesn't just totally confuse you.
Russ
Re: Importing project from SVN unable to run project on localhost? [message #873092 is a reply to message #872872] Thu, 17 May 2012 13:38 Go to previous message
Anyone?
Previous Topic:Cannot enter any characters in any of the text fields
Next Topic:Problem Marker
Current Time: Thu Feb 22 13:36:40 GMT 2018
Powered by FUDForum. Page generated in 0.03396 seconds
