Home » Modeling » UML2 » how to load int generals from Integer
how to load int generals from Integer [message #872444] Wed, 16 May 2012 06:06 Go to next message
jy zhang is currently offline jy zhangFriend
Hi all again,
I'm loading xmi2.1 file exported by EA, part of the xmi content is like below:
<primitivetypes>
	<packagedElement xmi:type="uml:Package" xmi:id="EAPrimitiveTypesPackage" name="EA_PrimitiveTypes_Package" visibility="public">
		<packagedElement xmi:type="uml:Package" xmi:id="EAJavaTypesPackage" name="EA_Java_Types_Package" visibility="public">
			<packagedElement xmi:type="uml:PrimitiveType" xmi:id="EAJava_int" name="int" visibility="public">
				<generalization xmi:type="uml:Generalization" xmi:id="EAJava_int_General">
					<general href="http:||schema.omg.org/spec/UML/2.1/uml.xml#Integer"/>
				</generalization>
			</packagedElement>
		</packagedElement>
	</packagedElement>
</primitivetypes>
When I load the xmi file, it seems it didn't dealt Integer as EClass (general of EA "int").
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value 'org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@5c0662 (eProxyURI: http:||schema.omg.org/spec/UML/2.1/uml.xml#Integer eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a728d6 (name: Classifier) (instanceClassName: null) (abstract: false, interface: false))' is not legal.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:83)
How could I fix this problem to load the xmi successfully?
Thanks a lot!
[Updated on: Wed, 16 May 2012 06:06]
Report message to a moderator
Re: how to load int generals from Integer [message #873198 is a reply to message #872444] Thu, 17 May 2012 16:59 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
And how do you load?
With Java code/UML model editor/Ecore model editor/....
Ed Willink
On 16/05/2012 07:06, jy zhang wrote:
> Hi all again,
> like below:
> <primitivetypes>
> </generalization>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </primitivetypes>
> mailto:'org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@5c0662
> mailto:org.eclipse.emf.ecore.impl.EClassImpl@1a728d6 (name:
> at
> Thanks a lot!
Re: how to load int generals from Integer [message #873463 is a reply to message #873198] Fri, 18 May 2012 09:37 Go to previous messageGo to next message
HI Ed,
I load the xmi file with my standalone java code,
and I've loaded simple xmi2.1 file exported by EA correctly.
load OK for xmi exported by EA (package0---Class0)
failed to load for (package--Class0--attribute0::int)
It seems EA creates generalization for its primitive type "int" which generals from http:||schema.omg.org/spec/UML/2.1/uml.xml#Integer,
and I've loaded the primitive types followed by http:||wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_load_a_UML_.28.uml.29_resource_from_a_standalone_application.3F, but still failed. (low level to paste web link)
Any ideas? Thanks a lot!
Edward Willink wrote on Thu, 17 May 2012 12:59
Ed Willink
Re: how to load int generals from Integer [message #886140 is a reply to message #872444] Thu, 14 June 2012 10:15 Go to previous messageGo to next message
max power is currently offline max powerFriend
Hi jy zhang,
have you managed to import the model with EAJAVA_.. types? I'm facing the same problem at the moment.
Re: how to load int generals from Integer [message #886276 is a reply to message #873463] Thu, 14 June 2012 15:41 Go to previous message
Sorry missed the response; been a busy time getting Juno ready.
I reviewed the UML2 Getting Started instructions and found a very
confusing mistake for novices; the Wiki has now been corrected as note
in https://bugs.eclipse.org/bugs/show_bug.cgi?id=382342. You may find
the reverse migration of UML2 4.0.0's UMLResourcesUtil.init() to
UML300ResourcesUtil.init in
https://bugs.eclipse.org/bugs/attachment.cgi?id=217303 helpful.
Ed Willink
On 18/05/2012 10:37, jy zhang wrote:
> HI Ed,
>> Hi
>> Regards
>> Ed Willink
Previous Topic:Load uml resource from an uploaded file
Next Topic:href="http://schema.omg.org/spec/UML/2.1/uml.xml#Integer"/> to EInt
Current Time: Fri Feb 23 05:01:39 GMT 2018
Powered by FUDForum. Page generated in 0.01618 seconds
