Home » Eclipse Projects » EGit / JGit » Can't commit and sometimes not add, but works on the CLI
Can't commit and sometimes not add, but works on the CLI [message #872002] Tue, 15 May 2012 09:28 Go to next message
Ivan V is currently offline Ivan VFriend
I can't commit and sometimes not add files, but can do these operations on the command line. I get these error messages respectively in an Eclipse dialog:
An internal error occurred
Exception caught during execution of commit command
Failed to add resource to index
Exception caught during execution of add command
My git files reside in a local directory.
I synchronize the directory to the web server using Unison, usually in that direction. Could that have anything to do with it?
How can I troubleshoot this?
Re: Can't commit and sometimes not add, but works on the CLI [message #874647 is a reply to message #872002] Mon, 21 May 2012 10:08 Go to previous messageGo to next message
Matthew Webber is currently offline Matthew WebberFriend
I don't have knowledge of that specific problem, but here are a few general observations:
Which version of EGit are you using?
Are your clones inside the workspace? This is not recommended.
How did you import the projects into your workspace? I have seen a few threads here recently, which suggest that you can have problems if the projects are imported in a certain way. You could try deleting the projects (but not the copy on disk), and then re-importing.
Matthew
Re: Can't commit and sometimes not add, but works on the CLI [message #874712 is a reply to message #872002] Mon, 21 May 2012 12:13 Go to previous messageGo to next message
Seiji Komatsu is currently offline Seiji KomatsuFriend
I'm also getting the same problem.
I saw the same message as Ivan's.
I see every time the same message, even after restarting Eclipse,
or disconnecting/reconnecting the project from/to the repos,
or refreshing the project.
Additionally, then I tried to commit from CUI with git command,
possibly no problem reported.
(Warning message is only shown, but I think this is not a problem with this discussion.
Warning message is:
warning: LF will be replaced by CRLF in source/Project/res/values/strings.xml
This is because of the git configuration, that is core.autocrlf=true)
And I say about my env.
No.
Firstly outside the project workspace, cloned the repository with git command.
Secondly imported with Eclipse GUI, without copying option.
Additiional Info
  • Eclipse Version: Version: Indigo Service Release 2 Build id: 20120216-1857
  • EGit/JGit Version: 1.3.0.201202151440-r
  • OS: Windows 7 64bit
  • Git command: Cygwin version
Re: Can't commit and sometimes not add, but works on the CLI [message #876048 is a reply to message #874647] Wed, 23 May 2012 20:03 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin RosenbergFriend
Matthew Webber skrev 2012-05-21 12.08:
This is a philosophical issue, not a technical one.
> Matthew
Re: Can't commit and sometimes not add, but works on the CLI [message #876049 is a reply to message #872002] Wed, 23 May 2012 20:05 Go to previous message
Ivan V skrev 2012-05-15 11.28:
The exceptions leave stack traces that often have useful information about what happened.
You can find then in the Error view or <workspace>/.metadata/.log
-- robin
Previous Topic:Recommended Git Repository layout for multi-project workspace?
Next Topic:jgit git-new-workdir?
Current Time: Fri May 25 03:36:31 GMT 2018
Powered by FUDForum. Page generated in 0.02235 seconds
