Home » Modeling » Epsilon » [Doubt] About Eugenia(Create node)
[Doubt] About Eugenia [message #870852] Wed, 09 May 2012 23:04 Go to next message
Pablo Silva is currently offline Pablo SilvaFriend
Hi guys!
First, I would like to apologize by english. I'm brazilian.
I'm new in EMFatic and Eugenia, and I'm developing a graphic editor in GMF by Eugenia.
How you can see in a part of my code:
@gmf.node(label="name", figure="rectangle")
class TGVariable extends TGObject {
  attr String[1] value = "";
class TGParameter extends TGVariable {
@gmf.node(label="name",figure="rectangle")
class TGFunction extends TGAbstractFunction {
  !resolve val TGParameter[*] parameters;
  attr String[1] parameters_str;
I noted TGVariable as a node and TGParameter extends this class. The problem is that when I generate the editor, even if not annotated TGParameter as a node, it can be create as one.
I wonder how to TGParameter not appear as a node in my editor.
Thanks for all and more one time sorry about the english.
Re: [Doubt] About Eugenia [message #870914 is a reply to message #870852] Thu, 10 May 2012 08:58 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris KolovosFriend
Hi Pablo,
By extending TGVariable, TGParameter also inherits all its annotations (i.e. @gmf.node). A workaround would be to use a polishing transformation [1] to delete the TGVariable-related elements in the .gmfxxx models, or just the creation tool in the .gmftool model.
Dimitris
[1] http://www.eclipse.org/epsilon/doc/articles/eugenia-polishing/
Re: [Doubt] About Eugenia [message #871047 is a reply to message #870914] Thu, 10 May 2012 16:14 Go to previous message
Oh ok!
I understand. I imagined I could do this only with Eugenia.
Thanks for the help!
Previous Topic:How to use EVL validation from GEF
Next Topic:Problem with EMFATIC file
Current Time: Fri Apr 20 14:57:04 GMT 2018
Powered by FUDForum. Page generated in 0.01431 seconds
