Home » Eclipse Projects » Rich Client Platform (RCP) » Plugin org.eclipse.core.runtime in target but invisible for plugins
Plugin org.eclipse.core.runtime in target but invisible for plugins [message #870227] Mon, 07 May 2012 10:50 Go to next message
Libor Jelinek is currently offline Libor JelinekFriend
Hello RCP folks,
I would like to ask you for help with setting up target defition for my RCP app. I am facing strange issue only with org.eclipse.core.runtime plugin that is included in target:
index.php/fa/9519/0/
index.php/fa/9518/0/
but invisible from required plugins browse dialog:
index.php/fa/9520/0/
I tried already everything: restart Eclipse, fetch RCP SDK directly from p2 site, from downloaded ZIP, clean all projects, ...
Weird is that if I switch to running platform (IDE's target), org.eclipse.core.runtime will become visible.
[Updated on: Mon, 07 May 2012 10:51]
Report message to a moderator
Re: Plugin org.eclipse.core.runtime in target but invisible for plugins [message #870239 is a reply to message #870227] Mon, 07 May 2012 12:19 Go to previous messageGo to next message
jps90 Mising name is currently offline jps90 Mising nameFriend
did you reload your targetplatform? There is a button in the dialog to do it.
Re: Plugin org.eclipse.core.runtime in target but invisible for plugins [message #870243 is a reply to message #870239] Mon, 07 May 2012 12:36 Go to previous messageGo to next message
Yes, sure, many times... It doesn't have any effect. Sad
Re: Plugin org.eclipse.core.runtime in target but invisible for plugins [message #870263 is a reply to message #870243] Mon, 07 May 2012 13:57 Go to previous message
Daniel Krügler is currently offline Daniel KrüglerFriend
On 2012-05-07 14:36, Libor Jelínek wrote:
> Yes, sure, many times... It doesn't have any effect. :(
Are you sure that the classes from org.eclipse.core.runtime are not
available already? Typically, org.eclipse.core.runtime is already
imported by other bundles and in this case it won't be part of the
selection list.
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:Position of HelpView
Next Topic:EFS usage in RCP (no workspace)
Current Time: Mon May 21 09:16:01 GMT 2018
Powered by FUDForum. Page generated in 0.01850 seconds
