Home » General (non-technical) » Eclipse Foundation » Glassfish can't works from Eclipse
Glassfish can't works from Eclipse [message #870123] Sun, 06 May 2012 18:09 Go to next message
Gustavo Hackum is currently offline Gustavo HackumFriend
Hello!
The Glasshfish not works from Eclipse.
See the error:
Server GlassFish 3.1 at localhost failed to start.
Re: Glassfish can't works from Eclipse [message #870409 is a reply to message #870123] Tue, 08 May 2012 04:42 Go to previous message
Gustovo,
This isn't a technical newsgroup and Glassfish isn't an Eclipse
project. You'll want to look closely at your launch configuration to
see which JVM you're using, the arguments you're passing, and compare
that to the command line invocation that works successfully.
On 06/05/2012 8:09 PM, Gustavo Hackum wrote:
> Hello!
> See the error:
Previous Topic:Eclipse Community Survey
Next Topic:EclipseCon Europe Call for Papers
Current Time: Sun Apr 22 14:41:57 GMT 2018
Powered by FUDForum. Page generated in 0.01296 seconds
