Home » Modeling » UML2 Tools » Hypermodel(Who uses Hypermodel?)
Hypermodel [message #870028] Sat, 05 May 2012 21:12 Go to next message
Arnedo Ramon is currently offline Arnedo RamonFriend
I don't know if this is the correct forum to ask this.
I tried to install hypermodel in eclipse Indigo, but I can't.
Is it possible to do it? Do I have to install anything before?
I did it using the site download.xmlmodeling.com/hyperModel/updates/site.xml
The next problem occurred: Cannot complete the install because one or more requires items could not be found.
Sofware currently installed: UML Modeling Extensions 1.0.0.201111140848 (org.openhealthtools.mdht.uml.feature.group 1.0.0.201111140848)
Missing requirement: UML UI Properties 1.0.0. 201111140848) requires 'bundle.org.eclipse.ocl 0.0.0' but it could not be found.
Cannot satisfy dependency:
From: UML Modeling Extensions 1.0.0.201111140848 (org.openhealthtools.mdht.uml.feature.group 1.0.0.201111140848)
To: org.openhealthtools.mdht.uml.ui.properties [1.0.0.201111140848]
Thanks for your help.
Ramón.
Re: Hypermodel [message #870032 is a reply to message #870028] Sat, 05 May 2012 21:34 Go to previous message
Ed Willink is currently offline Ed WillinkFriend
You are using a variety of third party tools. You should ask on their
newsgroups.
Ed Willink
On 05/05/2012 22:12, Arnedo Ramon wrote:
> I tried to install hypermodel in eclipse Indigo, but I can't. Is it
> 1.0.0.201111140848)
> Ramón.
Previous Topic:UML 2 Testing Profile
Next Topic:Package NOT Found when read .umlclass file by programmatically
Current Time: Fri Jan 19 23:53:12 GMT 2018
Powered by FUDForum. Page generated in 0.01877 seconds
