Home » Language IDEs » Java Development Tools (JDT) » List of source folders on build path
List of source folders on build path [message #111557] Tue, 28 October 2003 22:33 Go to next message
Vijay Ganesan is currently offline Vijay GanesanFriend
Member
Given an IJavaProject, how do I programatically get a list of all source
folders on build path?
I am able to get the output folder by using getOutputLocation() but I can't
seem to find anything in the API docs to get the source folders.
Vijay
Re: List of source folders on build path [message #111681 is a reply to message #111557] Wed, 29 October 2003 11:44 Go to previous messageGo to next message
Jerome Lanneluc is currently offline Jerome LannelucFriend
IJavaProject javaProject = ...;
ArrayList sourceFolders = new ArrayList();
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
IClasspathEntry[] entries = javaProject..getResolvedClasspath(true);
for (int i = 0; i < entries.length; i++) {
IClasspathEntry entry = entries[i];
if (entry.getEntryKind() == IClasspathEntry.CPE_SOURCE) {
IPath path = entry.getPath();
IFolder sourceFolder = root.getFolder(path);
sourceFolders.add(sourceFolder);
Jerome
"Vijay Ganesan" <vijay@mindspring.com> wrote in message
news:bnmqpl$cnh$1@eclipse.org...
can't
> Thanks
> Vijay
Re: List of source folders on build path [message #111797 is a reply to message #111681] Thu, 30 October 2003 03:40 Go to previous messageGo to next message
Member
Jerome,
This works except for this situation:
I created a project called "djsk" and added some files (in the default
package) without creating a source folder. The source folder on build path
is djsk
Now I get the following exception:
java.lang.IllegalArgumentException: Path must include project and resource
on the call:
Looks like I *have* to create folders in the project to put my source?
Vijay
--stack trace--
at org.eclipse.core.internal.utils.Assert.isLegal(Assert.java:5 5)
org.eclipse.core.internal.resources.Workspace.newResource(Wo rkspace.java:144
2)
org.eclipse.core.internal.resources.Container.getFolder(Cont ainer.java:129)
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bno94e$ull$1@eclipse.org...
> Jerome
> can't
> > Thanks
> > Vijay
Re: List of source folders on build path [message #112013 is a reply to message #111797] Thu, 30 October 2003 10:32 Go to previous message
No, you just need to check if the IPath has only 1 segment. In this case use
getProject(...) instead of getFolder(...).
Jerome
news:bnq157$vmf$1@eclipse.org...
> Jerome,
> is djsk
> on the call:
> Thanks
> Vijay
> --stack trace--
> at
> 2)
> at
> > Jerome
source
> > can't
> > > Thanks
> > > Vijay
Previous Topic:Compiling a single java source file
Next Topic:Crash while debugging java apps
Current Time: Sun Feb 18 01:50:33 GMT 2018
Powered by FUDForum. Page generated in 0.01631 seconds
