Home » Eclipse Projects » Remote Application Platform (RAP) » [GEF] thread safety issue
[GEF] thread safety issue [message #858770] Fri, 27 April 2012 09:38
Arnaud MERGEY is currently offline Arnaud MERGEYFriend
we were facing a strange issue with multiple users accessing a GEF diagram
(See the stack trace above)
I cannot really create a reproducible snippet, it requires to load a diagram on the same application from multiple browser.
But by debugging and investigating the code, I suspect this issue is caused by
DEFAULT_SOURCE_ANCHOR and DEFAULT_TARGET_ANCHOR private static final constants define d in org.eclipse.gef.editparts.AbstractConnectionEditPart
So these should probably be replaced by Session singleton.
What do you think ?
java.lang.ArrayIndexOutOfBoundsException: 1
at java.util.ArrayList.add(ArrayList.java:352)
org.eclipse.draw2d.ConnectionAnchorBase.addAnchorListener(ConnectionAnchorBase.java:33)
org.eclipse.draw2d.PolylineConnection.hookTargetAnchor(PolylineConnection.java:166)
org.eclipse.draw2d.PolylineConnection.setTargetAnchor(PolylineConnection.java:313)
org.eclipse.gef.editparts.AbstractConnectionEditPart.refreshTargetAnchor(AbstractConnectionEditPart.java:242)
org.eclipse.gef.editparts.AbstractConnectionEditPart.refresh(AbstractConnectionEditPart.java:225)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
org.eclipse.gef.editparts.AbstractConnectionEditPart.addNotify(AbstractConnectionEditPart.java:100)
org.eclipse.gef.editparts.AbstractConnectionEditPart.setParent(AbstractConnectionEditPart.java:268)
org.eclipse.gef.editparts.AbstractConnectionEditPart.setSource(AbstractConnectionEditPart.java:282)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addSourceConnection(AbstractGraphicalEditPart.java:260)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshSourceConnections(AbstractGraphicalEditPart.java:697)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:645)
org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
Arnaud
Previous Topic:ToolItem Markup support
Next Topic:[ANN] Migration from CVS to Git
Current Time: Sun May 20 23:43:49 GMT 2018
Powered by FUDForum. Page generated in 0.01852 seconds
