Connecting to Virgo's JMX [message #857513] |
Thu, 26 April 2012 15:58  |
Daniel McGreal Messages: 27 Registered: April 2012 |
Junior Member |
I'm trying to connect to Virgo's JMX port using the standard options of 2.1.
I found a bug-report at youtrack.jetbrains.com/ issue/ IDEA-72569 (sorry, had to disguise the link) which seems to say that the default options for JMX need to be changed before they'll work, but I'm not sure if this is even relevant to my experience although the symptoms seem to match.
import java.util.HashMap;
import java.util.Map;
import java.io.IOException;
import javax.management.MBeanServerConnection;
import javax.management.remote.JMXConnector;
import javax.management.remote.JMXConnectorFactory;
import javax.management.remote.JMXServiceURL;
public class Test{
private JMXConnector connector;
private MBeanServerConnection connection;
private void connect() throws IOException
JMXServiceURL jmxUrl = new JMXServiceURL("service:jmx:rmi:///jndi/rmi://localhost:9875/jmxrmi");
Map<String,Object> env = new HashMap<String,Object>();
env.put("jmx.remote.credentials", new String[] {"admin", "springsource"});
connector = JMXConnectorFactory.connect(jmxUrl, env);
connection = connector.getMBeanServerConnection();
public static void main(String... args){
try{ new Test().connect();
}catch (Exception e){ e.printStackTrace(); }
Quote:java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:304)
at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:128)
at javax.management.remote.rmi.RMIServerImpl_Stub.newClient(Unknown Source)
at javax.management.remote.rmi.RMIConnector.getConnection(RMIConnector.java:2370)
at javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:296)
at javax.management.remote.JMXConnectorFactory.connect(JMXConnectorFactory.java:267)
at Test.connect(Test.java:19)
at Test.main(Test.java:24)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1868)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:276)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:270)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1337)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:154)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:868)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:804)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:998)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1294)
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:685)
at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:111)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140)
at java.io.DataOutputStream.flush(DataOutputStream.java:123)
at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:229)
... 8 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:385)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
at sun.security.validator.Validator.validate(Validator.java:260)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:326)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:231)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:126)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1319)
... 19 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:196)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:268)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:380)
... 25 more
Have I done something wrong, or is there something I need to change to make this work?
Pre-thanks,
Dan.
FUDForum. Page generated in 0.02017 seconds
