Home » Archived » Visual Editor (VE) » Column select feature
Column select feature [message #110405] Tue, 01 November 2005 19:42 Go to next message
Ray Hurst is currently offline Ray HurstFriend
Is the Visual Editor group planning on adding a column select feature? The
text in the column select can be deleted or edited but only the text in the
selected column field would be touched.
Re: Column select feature [message #110421 is a reply to message #110405] Tue, 01 November 2005 20:04 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Could you please be a little more specific? We already allow changing
the column header's text?
Or are you asking about us helping by creating a cell editor and putting
this in your code so that you can change the text of cell in a
table/tree at runtime?
Rich Kulp
Re: Column select feature [message #110432 is a reply to message #110421] Tue, 01 November 2005 21:21 Go to previous messageGo to next message
Rich,
The column select feature allows you to select text in a column verses
selecting text in lines.
You can currently select lines of text for the cut, copy and paste
operations with the left mouse button.
The editor I use allows me to select a column of text for the cut, copy and
paste operations with the right mouse button.
Search and replace is also restricted to the selected text, line or column.
Ray Hurst
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dk8hp2$hf4$1@news.eclipse.org...
> Could you please be a little more specific? We already allow changing the
> this in your code so that you can change the text of cell in a table/tree
> at runtime?
>> The text in the column select can be deleted or edited but only the text
>> in the selected column field would be touched.
> Rich Kulp
Re: Column select feature [message #110443 is a reply to message #110432] Tue, 01 November 2005 23:28 Go to previous message
If you are talking about straight text selection, then that is part of
Eclipse's java editor. It has nothing to do with the Visual Editor. The
Visual Editor uses the Eclipse java editor for the text pane of the editor.
Rich Kulp
Re: Column select feature [message #611284 is a reply to message #110405] Tue, 01 November 2005 20:04 Go to previous message
Rich Kulp
Re: Column select feature [message #611285 is a reply to message #110421] Tue, 01 November 2005 21:21 Go to previous message
Rich,
Ray Hurst
> at runtime?
> Rich Kulp
Re: Column select feature [message #611286 is a reply to message #110432] Tue, 01 November 2005 23:28 Go to previous message
Rich Kulp
Previous Topic:Column select feature
Next Topic:VE tutorial: was( Re: Java GDI for Eclipse from eclipse.newcomer )
Current Time: Tue Apr 24 23:22:14 GMT 2018
Powered by FUDForum. Page generated in 0.01792 seconds
