Home » Archived » Memory Analyzer (MAT) » Inconsistent display of HashMap-keys
Inconsistent display of HashMap-keys [message #10034] Tue, 14 April 2009 11:43 Go to next message
Stefan Lotties is currently offline Stefan LottiesFriend
I just opened two heap dumps and noticed a HashMap having String's as keys
and wondered why the keys were so big.
The display looks like this:
HashMap
- table java.util.HashMap$Entry[xxx]
-- <class> java.util.HashMap$Entry[]
-- [yyy] java.util.HashMap$Entry @ 0x...
--- <class> java.util.HashMap$Entry
--- key java.lang.String @ 0x... some_string (retained heap: 24)
---- <class> java.lang.String
---- value char[zzz] @ 0x... some_other_string (retained heap: 30,336)
I'm a little bit confused why the key-Member has actually a very low
retained heap size and displays a different string than the char[] inside
the String which has an even bigger retained heap size. This can be seen
on every HashMap-Entry I checked from this map (it contains actually
>100.000 elements ;). Is there anything I'm doing wrong in my very simple
assumption that the key should be the same as the char[] inside it?
Stefan
Re: Inconsistent display of HashMap-keys [message #10057 is a reply to message #10034] Tue, 14 April 2009 13:54 Go to previous messageGo to next message
Erwin Margewitsch is currently offline Erwin MargewitschFriend
Hi Stefan,
your observation results from the way how Strings are implemented/working.
Every String consists of a reference to a char[]. Additionally every
String contains a length and an offset where the actual String inside the
char[] starts. This way many Strings can 'share' one char[]... imagine all
the substring methods which return a new String pointing to the same
char[] with a different offset or a different length.
You can search for the incoming objects for one of the big char[]. I bet
you will find not only one but many Strings ;-)
Erwin
Re: Inconsistent display of HashMap-keys [message #10080 is a reply to message #10057] Tue, 14 April 2009 14:52 Go to previous messageGo to next message
thanks for the information! I checked a couple of char[] an yes, I found a
couple of String-objects that hold the char[] as value-reference. For
example I checked a char[] with a retained heap size of 63,968 bytes and
found two String-objects each with a count of 30.
Somehow this seems to me like a huge design problem of the sun jvm's, but
I think I'm overlooking something very important ;)
Stefan
Re: Inconsistent display of HashMap-keys [message #10102 is a reply to message #10080] Tue, 14 April 2009 16:02 Go to previous message
Hi again,
mea culpa! I just took a look into the source of String and noticed that
calls like substring() really keep the reference to the original char[]
and the rest is as you told me. I didn't know that fact and well, now I'm
going to be much more careful when using substring() if I know that I'll
keep the sub-string for a longer time.
Thanks for the hint!
Stefan
Previous Topic:IOException with (MAT+DTFJ) when reading a phd file
Next Topic:Leak suspect newer end
Current Time: Mon Feb 26 02:11:21 GMT 2018
Powered by FUDForum. Page generated in 0.01968 seconds
