Home » Eclipse Projects » BIRT » Concatenating logfiles as datasource based on report parameters
Concatenating logfiles as datasource based on report parameters [message #856031] Wed, 25 April 2012 05:54 Go to next message
Ruben Durk is currently offline Ruben Durk
Hey there,
I have a folder full of log files. Each logfile contains 3 columns:
functionName (String of the function that is called)
data (dateTime of the measurement)
calls (integer of the number of calls in the 5 minute period)
I have 2 servers that each make one logfile a day.
Now what I want to do is to select the appropriate logfiles based on report paramters (e.g. select the data of both servers for the last two days) and merge/join these in one datasource so I can visualize the data.
When joining logfiles from the same server, I just want to keep the 3 columns, but more rows.
When joining logfiles from different servers, I want 4 columns. The 4th column indicates which server produced the data.
Can this be done within Birt? I know of joint data sets, but these produce more columns.
I added 4 example logfiles.
Thanks in advance!
Re: Concatenating logfiles as datasource based on report parameters [message #856418 is a reply to message #856031] Wed, 25 April 2012 12:34 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
You can do this but you will have to use a scripted data source. Take a
look at the attached example that combines multiple csv files. You
could add some parameters to determine which tsv files to combine.
Jason
On 4/25/2012 5:54 AM, Ruben Durk wrote:
> Hey there,
> Thanks in advance!
Jason Weathersby
BIRT Exchange
Re: Concatenating logfiles as datasource based on report parameters [message #857116 is a reply to message #856418] Thu, 26 April 2012 04:57 Go to previous message
I see! Thanks, haven't looked into scripted sources yet.
Previous Topic:Using joined Dataset twice
Next Topic:Problem with Birt Viewer 3.7.1 using Scripted data source
Current Time: Sat May 18 03:47:25 EDT 2013
Powered by FUDForum. Page generated in 0.01527 seconds
