Home » Language IDEs » ServerTools (WTP) » can't associate webtools JSP Editor any of files except for *.jsp
can't associate webtools JSP Editor any of files except for *.jsp [message #109863] Tue, 07 June 2005 18:48 Go to next message
sergom is currently offline sergomFriend
I can't associate webtools JSP Editor any of files except for *.jsp
(default file type)
I can't associate webtools JSP Editor any of files (example: *.cgi, *.inc)
except for *.jsp (default)
JSP Editor associating goes correctly, but in fact, during file editing
it's syntax doesn't get identified as jsp syntax.
Configuration:
OS: Linux Debian Sid 2.6.11
JAVA_HOME=/usr/lib/j2sdk1.4.2_05
eclipse 3.1M6 or eclipse 3.1M7
WTP 1.0M4 (stable) or wtp-I20050603
GEF-SDK-3.1M6
JEM-SDK-I20050415
emf-sdo-xsd-SDK-I200504141117
My actions:
Window -> Preferens -> General -> Editors -> File Associations
File types:
add *.cgi
Associated Editors:
add JSP Editor (webtools)
Create in current workspace test.cgi and type for example:
<%System.out.%>
syntax highlighting is off :(
code completion (<Ctrl>+<Tab>) is off :(
PS. If I remove Window -> Preferens -> General -> Editors -> File
Associations -> File types: -> *.jsp and open or create any jsp file,
syntax highlighting and code completion will be all the same active.
I think, that actually, webtools JSP Editor is registered statically with
*.jsp and consequently cannot leave or be renominated.
As a result of subquality work or a mistake, I do not know.
Thanks for the help!
Re: can't associate webtools JSP Editor any of files except for *.jsp [message #109905 is a reply to message #109863] Tue, 07 June 2005 21:31 Go to previous messageGo to next message
Philippe Ombredanne is currently offline Philippe OmbredanneFriend
"sergom" <sergo-79@mail.ru> wrote in message
news:844b6babb2f34da549b3491dc0f2bc21$1@www.eclipse.org...
> (default file type)
This is a known bug .
https://bugs.eclipse.org/bugs/show_bug.cgi?id=83309
https://bugs.eclipse.org/bugs/show_bug.cgi?id=90381
https://bugs.eclipse.org/bugs/show_bug.cgi?id=81710
It seems it has been fixed in head, but did not make it in the M4
milestones, from what I can see.
The proposed (immediate) workaround is (quoting) :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=81710#c6
"Yes, as a workaround you can append your filename extension to the
file-extensions attribute of this tag from
org.eclipse.jst.jsp.core/plugin.xml:
<content-type
file-extensions="jsp,jspf,jsf,jsv,jtpl,jspx,tag,tagf"
priority="high"
name="%JSP_Content_Type_Extension_Element.name"
id="jspsource"
base-type="org.eclipse.core.runtime.text"
default-charset="ISO-8859-1">
<describer
class=" org.eclipse.jst.jsp.core.internal.contenttype.ContentDescrib erForJSP "
</content-type>"
Re: can't associate webtools JSP Editor any of files except for *.jsp [message #109989 is a reply to message #109905] Wed, 08 June 2005 14:10 Go to previous messageGo to next message
Thanks for your answer and for helped to me!
Re: can't associate webtools JSP Editor any of files except for *.jsp [message #110025 is a reply to message #109905] Wed, 08 June 2005 16:09 Go to previous message
Another way (for WTP 1.0M4 and wtp-I20050603):
http://www.eclipse.org/newsportal/article.php?id=5046&gr oup=eclipse.webtools#5046
Previous Topic:can't associate webtools JSP Editor any of files except for *.jsp (default file
Next Topic:XML Catalog changes
Current Time: Sun May 20 12:20:18 GMT 2018
Powered by FUDForum. Page generated in 0.01926 seconds
