Home » Eclipse Projects » Remote Application Platform (RAP) » OSGI console doesn't startup
OSGI console doesn't startup [message #109779] Sat, 18 October 2008 18:37 Go to next message
Jürgen  Kilian is currently offline Jürgen KilianFriend
I'm new to RAP and struggling with deploying a simple rap in Tomcat.
I followed the instructions in the tutorials, creating the .war works,
Tomcat installs the .war, but I can't access it (.../sp_test results in
"Servlet delegate not registered.")
For further investigation it seems useful to have at least the OSGI
console available. After installing the bridge.war for testing (as
suggested in the tutorial), it seems that it works fine ("Servlet delegate
registered - org.eclipse.equinox.http.servlet.HttpServiceServlet" for
sp_test in url).
But after editing the web.xml to
.... <servlet-class>org.eclipse.equinox.servletbridge.BridgeServlet </servlet-class>
<init-param>
<param-name>commandline</param-name>
<param-value>-console</param-value>
</init-param>
<init-param>
<param-name>enableFrameworkControls</param-name>
<param-value>true</param-value>
</init-param>
(including a restart of Tomcat), there is no OSGI console for the bridge
rap or for any other rap using the -console param in web.xml
I'm using Tomcat 5.0 and JVM 1.6.0_07-b06
What environment (or trick) would it take to get the OSGI console starting
up?
Jürgen
Re: OSGI console doesn't startup [message #109826 is a reply to message #109779] Mon, 20 October 2008 07:14 Go to previous messageGo to next message
Stefan   is currently offline Stefan Friend
Hi Jürgen,
a common mistake is to include the javax.servlet bundles in the war-file
- could you check this, please?
If you modify the init-param to
<param-value>-console 54321</param-value>
you can access the OSGi-console via telnet on port 54321 to check the
bundle's state.
Stefan.
Jürgen Kilian schrieb:
> delegate registered -
> org.eclipse.equinox.http.servlet.HttpServiceServlet" for sp_test in url).
> But after editing the web.xml to ...
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> I'm using Tomcat 5.0 and JVM 1.6.0_07-b06 What environment (or trick)
> would it take to get the OSGI console starting up?
> Jürgen
Re: OSGI console doesn't startup [message #110000 is a reply to message #109779] Tue, 21 October 2008 16:07 Go to previous message
Originally posted by: fappel.innoopract.com
just to ensure that we don't miss anything. Did you activate the
framework controls section in the web.xml:
<!-- Framework Controls could be useful for testing purpose, but
we disable it in RAP environment per default -->
<init-param>
set this to true-><param-value>false</param-value>
</init-param>
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: "Jürgen" Kilian [mailto:kilian@noteserver.org]
Bereitgestellt: Samstag, 18. Oktober 2008 20:38
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: OSGI console doesn't startup
Betreff: OSGI console doesn't startup
delegate
sp_test in url).
class>
<init-param>
</init-param>
<init-param>
</init-param>
starting
up?
Jürgen
Previous Topic:UICallbacks are canceled when pressing ESC in Browser
Next Topic:problems with theming (RAP 1.1.1)
Current Time: Tue May 22 10:23:57 GMT 2018
Powered by FUDForum. Page generated in 0.01345 seconds
