Home » Newcomers » Newcomers » Debug Configuration Just Stops(Trying to debug a Eclipse plugin for Lotus Notes 8.5.1)
Debug Configuration Just Stops [message #854384] Mon, 23 April 2012 23:19 Go to next message
Anthony Missing name is currently offline Anthony Missing nameFriend
Below is the console output when I try to debug the Lotus Notes plugin. I will add that it used to work in the 8.5 version of Lotus Notes, but the changes have caused issues that I need to fix, but I can't connect via the Eclipse IDE to debug the plugin.
Configuration location:
file:/C:/Users/Joshua/workspace/.metadata/.plugins/org.eclipse.pde.core/Notes 8.5.1/
Configuration file:
file:/C:/Users/Joshua/workspace/.metadata/.plugins/org.eclipse.pde.core/Notes 8.5.1/config.ini loaded
Install location:
file:/C:/Progra~1/IBM/Lotus/Notes/framework/eclipse/
Framework located:
file:/C:/Lotus/framework/rcp/eclipse/plugins/org.eclipse.osgi_3.4.3.R34x_v20081215-1030-RCP20090909-1600.jar
Loading extension: com.ibm.rcp.core.logger.frameworkhook
eclipse.properties not found
Framework classpath:
file:/C:/Lotus/framework/rcp/eclipse/plugins/com.ibm.rcp.core.logger.frameworkhook_6.2.1.20090925-1604.jar
Debug options:
file:/C:/ide/eclipse/.options not found
Loading class "com.ibm.rcp.core.internal.logger.boot.LoggerConfig" failed
java.lang.ClassNotFoundException: com.ibm.rcp.core.internal.logger.boot.LoggerConfig
osgi> Time to load bundles: 20
Apr 23, 2012 3:53:43 PM
INFO: Log created; Log Size=100; Log Threshold=4
INFO: ServiceEvent REGISTERED
INFO: BundleEvent STARTED
INFO: FrameworkEvent STARTED
INFO: FrameworkEvent STARTLEVEL CHANGED
Apr 23, 2012 3:53:44 PM
Apr 23, 2012 3:53:44 PM com.ibm.rcp.lifecycle.internal.platform.PlatformStartup initializeSecurity
SEVERE: CWPLF0012E: The security provider com.ibm.rcp.security.ServiceProvider defined by preference com.ibm.rcp.securitysecurity.provider.1 failed to load.
Throwable occurred: java.lang.ClassNotFoundException: com.ibm.rcp.security.ServiceProvider
at java.lang.Class.forName(Class.java:136)
at com.ibm.rcp.lifecycle.internal.platform.PlatformStartup.initializeSecurity(PlatformStartup.java:608)
at com.ibm.rcp.lifecycle.internal.platform.PlatformStartup.start(PlatformStartup.java:78)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:1009)
at java.security.AccessController.doPrivileged(AccessController.java:251)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1003)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:984)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:350)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:355)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1074)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:616)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:508)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:299)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:489)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:211)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:321)
Apr 23, 2012 3:53:45 PM
INFO: BundleEvent STOPPED
SEVERE: An error occurred while automatically activating bundle com.ibm.rcp.security.jceproxy (1165).
Throwable occurred: org.osgi.framework.BundleException: The activator com.ibm.rcp.internal.security.SecurityPlugin for bundle com.ibm.rcp.security.jceproxy is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:146)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:980)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:265)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:427)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:193)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:370)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:434)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:399)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:609)
at java.lang.J9VMInternals.verifyImpl(Native Method)
at java.lang.J9VMInternals.verify(J9VMInternals.java:72)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:134)
at java.lang.J9VMInternals.newInstanceImpl(Native Method)
at java.lang.Class.newInstance(Class.java:1325)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:141)
Caused by: java.lang.NoClassDefFoundError: com.ibm.rcp.security.KeyStoreProxy$IKeyStoreSpiFactory
... 30 more
Caused by: java.lang.ClassNotFoundException: com.ibm.rcp.security.KeyStoreProxy$IKeyStoreSpiFactory
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:483)
... 36 more
SEVERE: FrameworkEvent.ERROR
Throwable occurred: org.osgi.framework.BundleException: The activator com.ibm.rcp.net.http.HttpPlugin for bundle com.ibm.rcp.net.http is invalid
Caused by: java.lang.NoClassDefFoundError: com.ibm.rcp.security.ssl.PlatformSSLProtocolSocketFactory
... 10 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.ibm.rcp.security.jceproxy (1165).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:125)
... 16 more
Caused by: org.osgi.framework.BundleException: The activator com.ibm.rcp.internal.security.SecurityPlugin for bundle com.ibm.rcp.security.jceproxy is invalid
... 25 more
... 30 more
... 36 more
SEVERE: FrameworkEvent ERROR
... 10 more
... 16 more
... 25 more
... 30 more
... 36 more
Starting application: 2851
INFO: FrameworkEvent INFO
SEVERE: An error occurred while automatically activating bundle com.ibm.rcp.security.auth (1160).
Throwable occurred: org.osgi.framework.BundleException: The activator com.ibm.rcp.internal.security.auth.AuthPlugin for bundle com.ibm.rcp.security.auth is invalid
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:443)
at com.ibm.notes.internal.managedsettings.NotesManagedSettingsPlugin.start(NotesManagedSettingsPlugin.java:103)
at com.ibm.rcp.internal.util.BundleManager.start(BundleManager.java:74)
at com.ibm.rcp.internal.util.BundleManager.start(BundleManager.java:164)
at com.ibm.rcp.lifecycle.internal.application.BundleControlImpl.start(BundleControlImpl.java:125)
at com.ibm.rcp.lifecycle.internal.application.BundleControlImpl.start(BundleControlImpl.java:106)
at com.ibm.rcp.lifecycle.application.BundleControl.start(BundleControl.java:89)
at com.ibm.rcp.personality.framework.internal.RCPApplication.run(RCPApplication.java:57)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:599)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:574)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:195)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.NoClassDefFoundError: com.ibm.rcp.security.auth.ExtLoginModuleProxy$ILoginModuleFactory
at com.ibm.rcp.internal.security.auth.AuthPlugin.<init>(AuthPlugin.java:54)
... 48 more
Caused by: java.lang.ClassNotFoundException: com.ibm.rcp.security.auth.ExtLoginModuleProxy$ILoginModuleFactory
... 55 more
Apr 23, 2012 3:53:45 PM com.ibm.rcp.lifecycle.internal.application.BundleControlImpl start
SEVERE: CWPLF1001E: The application lifecycle plugin failed to start bundle com.ibm.notes.managedsettings.provider
Throwable occurred: org.osgi.framework.BundleException: Exception in com.ibm.notes.internal.managedsettings.NotesManagedSettingsPlugin.start() of bundle com.ibm.notes.managedsettings.provider.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1028)
Caused by: java.lang.NoClassDefFoundError: com.ibm.rcp.security.auth.events.ILoginContextEventListener
... 27 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.ibm.rcp.security.auth (1160).
... 34 more
Caused by: org.osgi.framework.BundleException: The activator com.ibm.rcp.internal.security.auth.AuthPlugin for bundle com.ibm.rcp.security.auth is invalid
... 43 more
... 48 more
... 55 more
Apr 23, 2012 3:53:46 PM
Apr 23, 2012 3:53:46 PM com.ibm.rcp.personality.framework.internal.RCPApplication run
SEVERE: CLPDN0016E: Error starting RCPApplication com.ibm.rcp.personality.framework.RCPApplication
Throwable occurred: java.lang.NoClassDefFoundError: com.ibm.rcp.security.auth.login.CanceledLoginException
at com.ibm.rcp.platform.personality.DefaultWorkbenchWindowAdvisorFactory.create(DefaultWorkbenchWindowAdvisorFactory.java:26)
at com.ibm.rcp.personality.framework.internal.PersonalityDescriptor.createWorkbenchWindowAdvisor(PersonalityDescriptor.java:88)
at com.ibm.rcp.personality.framework.internal.RCPWorkbenchAdvisor.createWorkbenchWindowAdvisor(RCPWorkbenchAdvisor.java:1103)
at org.eclipse.ui.internal.WorkbenchWindow.getWindowAdvisor(WorkbenchWindow.java:3349)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(WorkbenchWindow.java:1194)
at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:398)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1710)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1708)
at org.eclipse.ui.internal.Workbench$19.runWithException(Workbench.java:1007)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at com.ibm.rcp.personality.framework.internal.RCPWorkbenchAdvisor.openWindows(RCPWorkbenchAdvisor.java:866)
at org.eclipse.ui.internal.Workbench$27.runWithException(Workbench.java:1363)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:178)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4251)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1358)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2314)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490)
at com.ibm.rcp.personality.framework.internal.RCPApplication.run(RCPApplication.java:73)
... 18 more
... 43 more
... 48 more
... 55 more
INFO: ServiceEvent UNREGISTERING
Apr 23, 2012 3:53:48 PM
INFO
Re: Debug Configuration Just Stops [message #855113 is a reply to message #854384] Tue, 24 April 2012 14:29 Go to previous message
Michael Rennie is currently offline Michael RennieFriend
Member
Your trace indicates there are a tonne of class not found and bundle activation exceptions - if I had to guess those are causing your problems.
Try correcting those problems and debugging again.
Previous Topic:How to invoke DOS commands with PHOTRAN
Next Topic:remove eclipe?
Current Time: Fri May 25 20:51:41 GMT 2018
Powered by FUDForum. Page generated in 0.03171 seconds
