Home » Newcomers » Newcomers » Binary Not Found C++ Linux
Binary Not Found C++ Linux [message #851986] Sat, 21 April 2012 14:44 Go to next message
Kyle K is currently offline Kyle KFriend
Ubuntu 12.04
VM was set, see config.ini below. Didn't help.
G++ and multilib were installed. No fix.
Tried wipe / restart / install. Same problem.
Binary not found error after trying to run the "hello world app"
p.s. i'm garbage w/ linux and coding.
config.ini:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505
-product
org.eclipse.epp.package.linuxtools.product
--launcher.defaultAction
[color=blue]-vm
/usr/local/java/jre1.6.0_31/bin/java[/color]
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.6
-XX:MaxPermSize=256m
-Xms40m
-Xmx384m
About::Configuration file
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20120208-0800
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-showsplash
-launcher
/usr/local/src/eclipse/eclipse
-name
Eclipse
--launcher.library
/usr/local/src/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so
-startup
/usr/local/src/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-exitdata
170001
-product
openFile
[color=green]-vm
/usr/bin/java[/color]
eclipse.home.location=file:/usr/local/src/eclipse/
eclipse.launcher=/usr/local/src/eclipse/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=epp.package.linuxtools
eclipse.product=org.eclipse.epp.package.linuxtools.product
eclipse.startTime=1335017628441
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx384m
-jar
[Updated on: Sat, 21 April 2012 14:46]
Report message to a moderator
Re: Binary Not Found C++ Linux [message #852796 is a reply to message #851986] Sun, 22 April 2012 10:20 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
On 2012.04.21 8:44, Kyle K wrote:
> Ubuntu 12.04
> [snip]
Reading the sticky posts at the top of the forum informs you that you
should not waste your time asking C/C++ development questions in this
forum. There is an Eclipse CDT forum for that.
Previous Topic:Jump to Matching Braces
Next Topic:No .exe in my download
Current Time: Mon Jan 22 08:45:16 GMT 2018
Powered by FUDForum. Page generated in 0.02686 seconds
