Home » Modeling » OCL » how to use the context expressions in OCL
how to use the context expressions in OCL [message #851735] Sat, 21 April 2012 08:34 Go to next message
Lucy Chan is currently offline Lucy ChanFriend
I just wondering how to use the context & inv expression in OCL specification in Helios Packages. I try several times, but the result suggests it's a error expresions with misplace with struct (s) or sth. like that. Who can give a simple example or give me some suggestions on reference books? Thanks sincerely.
Re: how to use the context expressions in OCL [message #851746 is a reply to message #851735] Sat, 21 April 2012 08:49 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
The Royal and Loyal example project has many examples.
Ed Willink
Re: how to use the context expressions in OCL [message #851823 is a reply to message #851746] Sat, 21 April 2012 10:50 Go to previous messageGo to next message
Thanks for your reply.
1:1:1:4 "inv:" misplaced construct(s)
The above is my error warning information. Did it mean that I wrote a wrong inv expression?
And the following expression is what I wrote: context ComponentInstance inv Login: self.multiplicity>0 where ComponentInstance is a class I defined. And Login means a instance of ComponentInstance.
Re: how to use the context expressions in OCL [message #851883 is a reply to message #851823] Sat, 21 April 2012 12:14 Go to previous messageGo to next message
You need to provide much more information; there is a limit to my telepathy.
What version of what tool are you using?
Ed Willink
> ComponentInstance.
Re: how to use the context expressions in OCL [message #851912 is a reply to message #851883] Sat, 21 April 2012 12:56 Go to previous messageGo to next message
the tool I'm using is Helios Packages for Eclipse Modeling Tools. The attachment is my file. I just want to verify if the number of the attribute multiplicity in Login ComponentInstance is >0, so I wrote the expression:
but it has some errors '1:1:1:4 "inv:" misplaced construct(s)' canyou help figure out where I made mistakes?
Thanks for your help sincerely.
Re: how to use the context expressions in OCL [message #851942 is a reply to message #851912] Sat, 21 April 2012 13:36 Go to previous messageGo to next message
But what tool? Sample Ecore Editor, Genmodel Editor, Console View,
OCLinEcore editoir, Complete OCL editor, Acceleo, QVTo, ....
Your attachment has no "context ComponentInstance inv Login:
self.multiplicity>0"
so what are you doing?
Ed Willink
On 21/04/2012 13:56, Lucy Chan wrote:
> the tool I'm using is Helios Packages for Eclipse Modeling Tools. The attachment is my file. I just want to verify if the number of the attribute multiplicity in Login ComponentInstance is>0, so I wrote the expression:
Re: how to use the context expressions in OCL [message #851996 is a reply to message #851942] Sat, 21 April 2012 14:59 Go to previous messageGo to next message
sry, I'm using the OCL interative to write OCL expressions.
Re: how to use the context expressions in OCL [message #852005 is a reply to message #851942] Sat, 21 April 2012 15:09 Go to previous messageGo to next message
I'm using the OCL interative in Console View
Re: how to use the context expressions in OCL [message #852574 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
OCL can be used in a variety of ways.
The Essential OCL expression language is embedded in a variety of larger
languages such as QVTo, Acceleo and ATL, and used with UML.
OCL by itself is almost useless; since it has no models to constrain.
Hence the need to embed in some language that provides context.
The Complete OCL language supports use of OCL in independent documents
that complement referenced meta-model.
The OCL Console supports Essential OCL expression entry and evaluation
using the prevailing Eclipse IDE selection as the modeling context.
Since you are using the Console you may only use Essential OCL
expressions. "context .... " is part of the Complete OCL syntax.
As from Juno M6, you may use the "Load Complete OCL Resource" menu
action to load a Complete OCL document (*.ocl extension) into another
modeling tool so that you can then exploit the additional OCLdefinitions
within the context of that tool while using the OCL Console for
interactive expression evaluation.
Ed Willink
Re: how to use the context expressions in OCL [message #852580 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
Ed Willink
Re: how to use the context expressions in OCL [message #852588 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
Ed Willink
Re: how to use the context expressions in OCL [message #852596 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
Ed Willink
Re: how to use the context expressions in OCL [message #852604 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
Ed Willink
Re: how to use the context expressions in OCL [message #852612 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
Ed Willink
Re: how to use the context expressions in OCL [message #852620 is a reply to message #852005] Sun, 22 April 2012 05:22 Go to previous messageGo to next message
HI
Ed Willink
Re: how to use the context expressions in OCL [message #852764 is a reply to message #852620] Sun, 22 April 2012 09:35 Go to previous message
Thanks a lot for your answer. It seems that what I have learnt is too limited. Hope to keep in touch with you. Thanks for your help again.
Previous Topic:Parse OCL Constraints - Model Instance of an UML Profile
Next Topic:OCL console: querying when having multiples resources
Current Time: Wed May 23 15:19:14 GMT 2018
Powered by FUDForum. Page generated in 0.01982 seconds
