Home » Language IDEs » Java Development Tools (JDT) » Adding Struts 2.x + Spring 2.5 + Hibernate 3.1 capabilities(Adding Struts 2.x + Spring 2.5 + Hibernate 3.1 capabilities)
Adding Struts 2.x + Spring 2.5 + Hibernate 3.1 capabilities [message #850748] Fri, 20 April 2012 09:38 Go to next message
Ram chandra is currently offline Ram chandraFriend
Hi Team,
I am trying to develop a web application with struts2.0, spring2.5 and hibernate3.1. Will it be possible for you to provide me any tutorial or a document which has the detailed steps to add the struts, spring and hibernate JAR's into the build path.
Basically, what I am looking for is the order in which these JAR's are added and also the process of mapping spring with struts config(xml) file and hibernate with spring context file.
Also, it would be really helpful, if you can provide me a sample folder structure of a web project with all the jars imported.
Any help with the above would be very helpful.
Many thanks for your assistance in advance !!!
Please find below the information required from my end :-
** System properties:
OS=Windows7
Java version=1.6.0.70
*** Eclipse details:
MEclipse Java EE IDE for Web Developers.
Version: Indigo Service Release 2
Build id: 20120216-1857
Ram
Re: Adding Struts 2.x + Spring 2.5 + Hibernate 3.1 capabilities [message #850828 is a reply to message #850748] Fri, 20 April 2012 11:12 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Please ask at the WTP-Forum
Tom
Am 20.04.12 11:38, schrieb Ram chandra:
> Hi Team,
> ** System properties: OS=Windows7 Java version=1.6.0.70
> *** Eclipse details: MEclipse Java EE IDE for Web Developers.
> Thanks, Ram
Previous Topic:Dynamic Web project don't copy any file to wtpwebapps directory
Next Topic:IWorkbenchWindow at ApplyRefactoringScriptAction
Current Time: Fri May 25 22:49:56 GMT 2018
Powered by FUDForum. Page generated in 0.01956 seconds
