Home » Eclipse Projects » JFace » Eclipse software update: NPE popup on saving edited source
icon4.gif  Eclipse software update: NPE popup on saving edited source [message #850615] Fri, 20 April 2012 07:10 Go to next message
Karsten Wutzke is currently offline Karsten WutzkeFriend
Hello all,
I've upgraded Eclipse 3.7 to the latest software. I checked all that could be updated.
Now however, I keep getting the following popup:
index.php/fa/8003/0/
Exception (copied from the Eclipse .log):
!ENTRY org.eclipse.jface 4 2 2012-04-20 08:54:58.618
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
	at com.sun.enterprise.jst.server.sunappsrv.actions.PreludeUpdateCenterAction.accept(PreludeUpdateCenterAction.java:171)
	at com.sun.enterprise.jst.server.sunappsrv.actions.AppServerContextAction.selectionChanged(AppServerContextAction.java:238)
	at org.eclipse.ui.actions.SelectionProviderAction.selectionChanged(SelectionProviderAction.java:143)
	at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
	at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
	at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1725)
	at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1139)
	at org.eclipse.ui.navigator.CommonViewer.setSelection(CommonViewer.java:377)
	at org.eclipse.jface.viewers.Viewer.setSelection(Viewer.java:394)
	at org.eclipse.wst.server.ui.internal.cnf.ServerDecoratorsHandler$1.run(ServerDecoratorsHandler.java:58)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Note this appears twice in the log, thus the two NPEs in the popup.
Note, that I'm using JBoss Tools. When I edit any Java file a popup dialog appears on every save operation while the JBoss 7 server is running. It could hardly be more annoying to be honest!
What's wrong here? Can this be fixed? Who's responsible?
I cannot revert to the previous install, it fails with some error that some older repos aren't found or so.
Karsten
[Updated on: Fri, 20 April 2012 07:18]
Report message to a moderator
Re: Eclipse software update: NPE popup on saving edited source [message #850649 is a reply to message #850615] Fri, 20 April 2012 07:48 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Not sure who contributes the
com.sun.enterprise.jst.server.sunappsrv.actions but it sounds like WTP?
JFace only catches the exception and logs it.
Tom
Am 20.04.12 09:10, schrieb Karsten Wutzke:
> Hello all,
> could be updated.
> Now however, I keep getting the following exception (copied from the
> Eclipse .log):
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> Note this appears twice in a row and in the log.
> Karsten
Re: Eclipse software update: NPE popup on saving edited source [message #850664 is a reply to message #850615] Fri, 20 April 2012 08:05 Go to previous messageGo to next message
Note, I'm also using the GlassFish plugins. It looks like
http://java.net/nonav/projects/glassfishplugins/lists/cvs/archive/2008-11/message/21
has reappeared. I wonder how this can happen...
Karsten
[Updated on: Fri, 20 April 2012 08:09]
Re: Eclipse software update: NPE popup on saving edited source [message #850712 is a reply to message #850664] Fri, 20 April 2012 08:57 Go to previous messageGo to next message
How can I revert the plugin to a previous version in Eclipse?
Karsten
Re: Eclipse software update: NPE popup on saving edited source [message #850738 is a reply to message #850712] Fri, 20 April 2012 09:24 Go to previous messageGo to next message
Window > About > Installation Details
Tom
Am 20.04.12 10:57, schrieb Karsten Wutzke:
> Karsten
Re: Eclipse software update: NPE popup on saving edited source [message #851119 is a reply to message #850738] Fri, 20 April 2012 17:07 Go to previous message
Doesn't work for me. I had to delete all plugins and features manually.
Karsten
Previous Topic:Java Editor ToolTip
Next Topic:Operation on Collapsed Tree Item
Current Time: Thu Apr 26 17:36:02 GMT 2018
Powered by FUDForum. Page generated in 0.01923 seconds
