Home » Eclipse Projects » BIRT » Using BIRT with jsf4birt.jar on tomcat server/websphere(Render report generated by BIRT on jsp page.)  () 1 Vote
Using BIRT with jsf4birt.jar on tomcat server/websphere [message #849729] Thu, 19 April 2012 12:00 Go to next message
Debarshi Dasgupta is currently offline Debarshi DasguptaFriend
Hello All,
For few days I am working on BIRT and jsf4birt. I have followed the below mentioned steps to display charts generated by BIRT on jsp page using "birt:birtWrapper" tag.
1. Copied all the JARs from Report Engine to my project/WEB-INF/lib directory.
2. Copied the birt-runtime/Report Engine/plugins and birt-runtime/ReportEngine/configuration directories to the platform directory.
Added the required context params to the web.xml.
Used as :
<birt:birtWrapper id="t" reportDesign="/reports/new_report.rptdesign" rendered="true">
<f:param name="country" value="USA"></f:param>
</birt:birtWrapper>
Report name : new_report.rptdesign
When I start the server I get the below exception :
SEVERE: JSF1054: (Phase ID: RENDER_RESPONSE 6, View ID: /workpages/pageb.jsp) Exception thrown during phase execution: javax.faces.event.PhaseEvent[source=com.sun.faces.lifecycle.LifecycleImpl@1f528ab]
Apr 18, 2012 8:04:16 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet Faces Servlet threw exception
at org.eclipse.birt.report.engine.api.impl.ReportEngine$EngineExtensionManager.<init>(ReportEngine.java:819)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:111)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$1.run(ReportEngineFactory.java:18)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$1.run(ReportEngineFactory.java:1)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory.createReportEngine(ReportEngineFactory.java:14)
at com.exadel.jsfbirt.engine.BirtEngine.getBirtEngine(BirtEngine.java:80)
Platform details :
JSF Version : 1.2
Java Compiler : 1.5
Tomcat Version : 6
IDE : Eclipse Indigo/RSA
Please help as I have checked all the links but I get the above mentioned error.
Re: Using BIRT with jsf4birt.jar on tomcat server/websphere [message #850437 is a reply to message #849729] Fri, 20 April 2012 03:18 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
What version of BIRT are you using?
Jason
On 4/19/2012 8:01 AM, Debarshi Dasgupta wrote:
> Hello All,
> directory.
> directory.
> Used as :
> rendered="true">
> </birt:birtWrapper>
> javax.faces.event.PhaseEvent[source=mailto:com.sun.faces.lifecycle.LifecycleImpl@1f528ab]
> invoke
> java.lang.NullPointerException
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> Platform details :
> JSF Version : 1.2
> Java Compiler : 1.5
> Tomcat Version : 6
> mentioned error.
Re: Using BIRT with jsf4birt.jar on tomcat server/websphere [message #850544 is a reply to message #849729] Fri, 20 April 2012 05:51 Go to previous messageGo to next message
Thanks Jason for your reply. Your replies are very helpful.
Birt runtime version : 3_7_2
I have also copied jars from the lib folder of exadel-jsf4birt-demo module.
The jsf tags are working fine but the page with birt:birtWrapper is causing the exception.
And added the following context-params in web.xml
<context-param>
<param-name>actuate.serverUrl</param-name>
<param-value>http localhost:8900 iportal</param-value> (cant add links, that is why typed the url in this way)
</context-param>
<context-param>
<param-name>actuate.serverLogin</param-name>
<param-value>administrator</param-value>
</context-param>
<context-param>
<param-name>actuate.serverPassword</param-name>
<param-value></param-value>
</context-param>
I am also adding the screen shots of the jars added since module size exceeds the permitted file size.
[Updated on: Fri, 20 April 2012 05:56]
Report message to a moderator
Re: Using BIRT with jsf4birt.jar on tomcat server/websphere [message #851105 is a reply to message #850544] Fri, 20 April 2012 16:47 Go to previous messageGo to next message
Can you take a look at this thread:
http://www.birt-exchange.org/org/forum/index.php/topic/23053-birt-3-7-and-jsf4birt/page__s__4412f80c7cd5e7495408a41162654916
Jason
> <context-param>
> </context-param>
> <context-param>
> </context-param>
> <context-param>
> </context-param>
Re: Using BIRT with jsf4birt.jar on tomcat server/websphere [message #852188 is a reply to message #851105] Sat, 21 April 2012 19:23 Go to previous message
Finally the code worked for me. Steps to be followed are as follows :
1. Make a dynamic web project (jsf project if you want to use jsf tags).
2. Once your project is ready prepare your report. Prepare your data sets for report/chart generation, a sample query is mentioned below.
select count(customernumber) cuscount,State
from customers
where country=? -- this is the parameter you can give as input
group by state
3. Once you are done with this part add following parameters to web.xml
<context-param>
<param-value>http: localhost:8900 iportal</param-value>(please add //,/ respectively in the blank spaces.)
</context-param>
<context-param>
</context-param>
<context-param>
</context-param>
<context-param>
<param-name>org.eclipse.birt.configPath</param-name>
<param-value>/configuration/config.ini</param-value>
</context-param>
Place the configuration folder inside WEB-CONTENT.
If this is not done properly you can get null pointer exception.
4. Copy the "platform" folder inside WEB-INF.
5. The list of required jars are mentioned in the screen attached with this post.
(Downloading the dummy module of jsf4birt from exadel website will be helpful).
6. A tricky part that I found after struggling for few days. If you get version mismatch error or unsupported exception, open your reportfile.rptdesign in text editor u will get something like
<report xmlns="http //www.eclipse.org/birt/2005/design" version="3.2.20" id="1">
Change this version to the one that is supported by your server/IDE. I changed it from 3.2.23 to 3.2.20.
7. Finally the birt:birtWrapper worked for me. Where country is my parameter.
<birt:birtWrapper id="t" reportDesign="customerdetails.rptdesign" rendered="true">
<f:param name="country" value="#{form.country}"></f:param></birt:birtWrapper>
And then finally it worked for me.
I am trying to explore more features of BIRT like adding comments to a point on chart and generating reports in pdf format. Please do let me know if you are aware of these stuffs.
Special thanks to Jason for his valuable posts !!
Previous Topic:How can I retrieve data?
Next Topic:Set a variable using the output of a SQL query
Current Time: Thu Feb 22 23:18:47 GMT 2018
Powered by FUDForum. Page generated in 0.03331 seconds
