Home » Modeling » TMF (Xtext) » append instead of appendImmediate for "AFTER" in loops
append instead of appendImmediate for "AFTER" in loops [message #849568] Thu, 19 April 2012 09:03 Go to next message
Christoph ZwickerFriend
Hi all,
It seems that in FOR loops, the "AFTER" instruction translates into a ".append" call. I would have expected it to be ".appendImmeditate" in order to have symmetrical behavior with "SEPARATOR"...
What I would like to do when declaring enum instances is:
«FOR field : fields SEPARATOR ", //$NON-NLS-1$" AFTER "; //$NON-NLS-1$"»
	«field.declaration»
«ENDFOR»
The only workaround I found to simulate the expected behavior is the following:
«FOR field : fields SEPARATOR ", //$NON-NLS-1$"»
	«field.declaration»«IF field.equals(fields.last)»; //$NON-NLS-1$«ENDIF»
«ENDFOR»
Am I missing something? If not: I guess you would not accept this as a bug as it would change the current behavior. Any chance you might introduce a new keyword, e.g. "LAST" resulting in a "appendImmediate"?
Chris
Re: append instead of appendImmediate for "AFTER" in loops [message #849728 is a reply to message #849568] Thu, 19 April 2012 11:56 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Chris,
the expressions BEFORE and AFTER are inserted before or after the actual
FOR LOOP. They are not meant to appear immediatly after the expression
in the for loop itself.
You could experiment with something like this:
«FOR field : fields SEPARATOR ", //$NON-NLS-1$\n" AFTER ";
//$NON-NLS-1$"»«field.declaration»«ENDFOR»
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 19.04.12 11:03, schrieb Christoph Zwicker:
> Hi all,
> «field.declaration»
> «ENDFOR»
> following:
> «ENDFOR»
> Chris
Re: append instead of appendImmediate for "AFTER" in loops [message #851032 is a reply to message #849728] Fri, 20 April 2012 15:25 Go to previous message
Hi Sebastian
Thank you for your reply. I had tried the solution you suggest earlier, but it destroys the indentation. I'll live with my workaround, it works fine - it's just a little clumsy Wink
The thing is that "after the loop" doesn't necessarily need to mean that there should be an empty line added imho: if my method called is something like the code below, I'm explicitly trying to avoid an empty line added. It's confusing to me that the generated code adds a newline after each method call instead of before it...
def foo '''
	bar'''
Thanks anyhow,
Chris
Previous Topic:how to avoid compiling Xtend classes in running Eclipse
Next Topic:Content Assist don't work in first column of second line...
Current Time: Mon May 21 13:18:10 GMT 2018
Powered by FUDForum. Page generated in 0.01589 seconds
