Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] HbDataStore.reinitialize()
[Teneo] HbDataStore.reinitialize() [message #107687] Fri, 18 January 2008 06:15 Go to next message
Stefan Winkler is currently offline Stefan Winkler
Hi all,
on http://www.elver.org/hibernate/dynamic.html it says:
Step 2: Reconfigure Hibernate and the Relational Database
The EPackage has been created now Hibernate should be reconfigured and
the database schema should be updated. To reinitialize a HbDataStore the
reinitialize method should be called (not the initialize method).
// reinitialize hibernate and update the database schema
hbds.reInitialize();
However, I do not see the method reInitialize() in HbDataSource.
Is it new? (I have 0.8.0.v200712280940 here ...)
Or did I miss something?
Stefan
Re: [Teneo] HbDataStore.reinitialize() [message #107702 is a reply to message #107687] Fri, 18 January 2008 06:35 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Stefan,
The docs are out-of-date on this, I will update them.
You can call initialize again to re-initialize the datastore. I removed the reInitialize method a
while back because it afterall made more sense (to me) to explicitly call initialize again instead
of having an extra method in the api.
gr. Martin
Stefan Winkler wrote:
> Hi all,
> Cheers,
> Stefan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] HbDataStore.reinitialize() [message #614049 is a reply to message #107687] Fri, 18 January 2008 06:35 Go to previous messageGo to next message
Hi Stefan,
gr. Martin
> Hi all,
> Cheers,
> Stefan
The Netherlands
Re: [Teneo] HbDataStore.reinitialize() [message #665991 is a reply to message #107702] Mon, 18 April 2011 09:34 Go to previous messageGo to next message
Liviu-Marian Negrila is currently offline Liviu-Marian Negrila
Member
I don't think you can call the initialize() method on a data store with
teneo in version 1.1.2
See the post with the subject:
<<Re: [Teneo] Re: HBSessionDataStore.initialize() / reinitialize?>>
Liviu
On 18/01/08 13:35, Martin Taal wrote:
> Hi Stefan,
> the reInitialize method a while back because it afterall made more sense
> (to me) to explicitly call initialize again instead of having an extra
> method in the api.
> gr. Martin
>> Hi all,
>> the reinitialize method should be called (not the initialize method).
>> Cheers,
>> Stefan
Re: [Teneo] HbDataStore.reinitialize() [message #666132 is a reply to message #665991] Tue, 19 April 2011 05:00 Go to previous message
For the record, this should be solved now in the new build published today.
gr. Martin
On 04/18/2011 03:34 PM, Liviu Negrila wrote:
> I don't think you can call the initialize() method on a data store with teneo in version 1.1.2
> Thanks
> Liviu
>> Hi Stefan,
>> method in the api.
>> gr. Martin
>>> Hi all,
>>> Cheers,
>>> Stefan
The Netherlands
Cell: +31 (0)6 288 48 943
Previous Topic:HBSessionDataStore.initialize() / reinitialize?
Next Topic:[EEF] Elements don't show in AdvancedReferencesTable
Current Time: Wed Jun 19 17:19:07 EDT 2013
Powered by FUDForum. Page generated in 0.01568 seconds
