Home » Eclipse Projects » BIRT » Birt Bar Interval Chart
Birt Bar Interval Chart [message #843785] Fri, 13 April 2012 07:13 Go to next message
Nepomuk Seiler is currently offline Nepomuk Seiler
Member
I want to create a bar which looks as this
(Categories)
A: ######      ####        ####
B:     ########               #########
C:                 ########
  12:00 13:00 14:00 15:00 16:00 17:00 (Timeline)
First I tried the Gantt chart, but it I wasn't able
to create the categories Axis with distinct Categories.
So for the example chart above, BIRT creates 3x A Category,
2x B Category and 1x C Category. Grouping on the Y-Axis
didn't helped, as it didn't merged the intervalls.
The Barchart doesn't support intervals at all AFAIK.
Is there a possibility to achieve this?
cheers,
Muki
Re: Birt Bar Interval Chart [message #844033 is a reply to message #843785] Fri, 13 April 2012 12:09 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
When you did this with the Gantt chart did you set grouping the category
axis? This is done on the second tab of the chart wizard. It is
accessed with the button next to the expression.
Jason
On 4/13/2012 7:13 AM, Nepomuk Seiler wrote:
> (Categories)
> A: ###### #### ####
> C: ########
> cheers,
> Muki
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #844039 is a reply to message #843785] Fri, 13 April 2012 12:09 Go to previous messageGo to next message
Jason
> (Categories)
> A: ###### #### ####
> C: ########
> cheers,
> Muki
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #846627 is a reply to message #844033] Mon, 16 April 2012 06:56 Go to previous messageGo to next message
Member
Hi. I used the grouping feature on the second page. With and without grouping enabled (with step 1).
The sample data looks like this:
start		end		label
16.04.2012	20.04.2012	Label A
18.04.2012	21.04.2012	Label B
21.04.2012	26.04.2012	Label A
25.04.2012	28.04.2012	Label C
28.04.2012	01.05.2012	Label B
31.04.2012	06.05.2012	Label C
With grouping disabled
http://ubuntuone.com/3LTpvz1CeYMeWJ7fZ1y3Tw
With grouping enabled
http://ubuntuone.com/7fknUAZIYduLUezJDdglQp
Re: Birt Bar Interval Chart [message #846992 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
I got it to combine two categories with the same name but it does not
have a space between the task end and start. I used min and max
aggregates. You may want to log a bug for this.
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #846996 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #847000 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #847004 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #847008 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #847012 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #847016 is a reply to message #846627] Mon, 16 April 2012 19:33 Go to previous messageGo to next message
Jason
> start end label
Jason Weathersby
BIRT Exchange
Re: Birt Bar Interval Chart [message #847284 is a reply to message #847016] Tue, 17 April 2012 02:57 Go to previous messageGo to next message
Member
I reported a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=376935
Re: Birt Bar Interval Chart [message #847726 is a reply to message #847284] Tue, 17 April 2012 11:39 Go to previous message
Thanks for posting the bug number.
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Dependant entities in the same report table
Next Topic:Legend entries for curve fitting lines
Current Time: Thu May 23 01:23:07 EDT 2013
Powered by FUDForum. Page generated in 0.09819 seconds
