| [Xpand] Dynamic position of generated text [message #843658] |
Fri, 13 April 2012 04:46  |
Hai Le Messages: 9 Registered: April 2012 Location: Vietnam |
Junior Member |
Hi all,
Please take a look at my problem. Let's consider that we have 3 very simple templates in Xpand: class, variable and method.
«DEFINE class FOR X»
public class MyClass {
«EXPAND variableDec»
«EXPAND method»
«ENDDEFINE»
«DEFINE variable FOR X»
int a = 0;
int b = 0;
int c = 0;
«ENDDEFINE»
«DEFINE method FOR X»
public static String methodA() {
«EXPAND variable»
«ENDDEFINE»
The output shall be:
int a = 0;
int b = 0;
int c = 0;
int a = 0;
int b = 0;
int c = 0;
So I wonder that do we have any way to make the text generated right at the place where EXPAND statement is placed. Specifically, if we update the template variable as:
int a = 0;
int b = 0;
int c = 0;
«ENDDEFINE»
And the calling of variable template in other templates:
«EXPAND method»
«ENDDEFINE»
«EXPAND variable»
«ENDDEFINE»
Then the expected text is generated as:
int a = 0;
int b = 0;
int c = 0;
int a = 0;
int b = 0;
int c = 0;
Hope that everyone could understand my situation. Thanks for any help!
| Re: [Xpand] Dynamic position of generated text [message #843730 is a reply to message #843704] |
Fri, 13 April 2012 06:07   |
Junior Member |
Hi Christian,
Of course it is always working. The point here is that I have a "common" template just like the above sample:
int a = 0;
int b = 0;
int c = 0;
«ENDDEFINE»
This template shall be called from the others such as:
«EXPAND variable»
«ENDDEFINE»
--> The output here is OK:
int a = 0;
int b = 0;
int c = 0;
However, due to this template is common, so there is another usecase like this:
«EXPAND variable»
«ENDDEFINE»
The code is actually generated as:
int a = 0;
int b = 0;
int c = 0;
But expected as:
int a = 0;
int b = 0;
int c = 0;
int a = 0;
int b = 0;
int c = 0;
How do you think?
[Updated on: Fri, 13 April 2012 06:08] Report message to a moderator
FUDForum. Page generated in 0.02256 seconds
