Re: Embedding QT widgets in SWT [message #843928 is a reply to message #842789] |
Fri, 13 April 2012 14:06   |
Grant Gayed Messages: 2151 Registered: July 2009 |
Hi Seref,
As you're probably aware, you'll need to use the port of SWT for Qt that
is being developed at http://code.google.com/a/eclipselabs.org/p/swtqt/
(I have not tried using it). If this works well for you in general then
have a look at
http://www.eclipse.org/articles/Article-Writing%20Your%20Own%20Widget/Writing%20Your%20Own%20Widget.htm
for info on creating a new widget, and in particular its "Wrapping a
Native Widget" section.
HTH,
Grant
On 4/12/2012 12:01 PM, Seref Arikan wrote:
> Greetings, I've been developing various tools with RCP and some serious
> plugin work is on the horizon.
> There are some cases where I can make a lot faster progress if I could
> just develop a particular widget with QT, and embed that into SWT as a
> custom SWT component.
> Google searches present bits an pieces of examples, and I can use them
> if I can't find any proper documents that explains how to extend SWT
> with QT (or with other native components).
> Is there any documentation/book/tutorial that explains wrapping native
> widgets with SWT? QT is my target, but anything that goes into details
> of the topic would help.
> After much thinking I've decided to go into this direction, since it'll
> be the most productive combination of technologies given my circumstances.
> Any feedback would be much appreciated.
> Best regards
> Seref
FUDForum. Page generated in 0.01602 seconds
