Home » Language IDEs » Java Development Tools (JDT) » 'org.eclipse.wst.xml.core 0.0.0' but it could not be found
'org.eclipse.wst.xml.core 0.0.0' but it could not be found [message #840308] Mon, 09 April 2012 23:48 Go to next message
Jirong Hu is currently offline Jirong HuFriend
wiki.eclipse.org/Maven_Integration
While I try to download the m2e plugin from the address below to my RTC 3 (eclipse 3.6), I got this error.
download.eclipse.org/technology/m2e/releases
How can I fix this?
And why this rule?!: You cannot use links until you have posted more than 25 messages.
Jirong
Cannot complete the install because one or more required items could not be found.
Software being installed: m2e - Maven Integration for Eclipse 1.0.100.20110804-1717 (org.eclipse.m2e.feature.feature.group 1.0.100.20110804-1717)
Missing requirement: m2e - Maven Integration for Eclipse 1.0.100.20110804-1717 (org.eclipse.m2e.feature.feature.group 1.0.100.20110804-1717) requires 'org.eclipse.wst.xml.core 0.0.0' but it could not be found
Re: 'org.eclipse.wst.xml.core 0.0.0' but it could not be found [message #841574 is a reply to message #840308] Wed, 11 April 2012 13:39 Go to previous messageGo to next message
Satyam Kandula is currently offline Satyam KandulaFriend
On the install dialog box, check the option 'Contact all update sites during install to find required software'f
Re: 'org.eclipse.wst.xml.core 0.0.0' but it could not be found [message #841593 is a reply to message #841574] Wed, 11 April 2012 14:12 Go to previous messageGo to next message
it is checked, no help.
Jirong
Re: 'org.eclipse.wst.xml.core 0.0.0' but it could not be found [message #841733 is a reply to message #841593] Wed, 11 April 2012 17:21 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
org.eclipse.wst.xml.core comes from WTP, so you should also make sure that the Helios Update Site (http://download.eclipse.org/releases/helios/) and WTP Helios-specific site (http://download.eclipse.org/webtools/repository/helios/) are listed and searched as well.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: 'org.eclipse.wst.xml.core 0.0.0' but it could not be found [message #850919 is a reply to message #841733] Fri, 20 April 2012 13:18 Go to previous messageGo to next message
Sabir pasha is currently offline Sabir pashaFriend
Member
This error is seen when we try to install even Android's ADT plugin.. But as Nitin said we need to search helios update site as well .
Not sure if this error is present even with Eclipse 3.7
Re: 'org.eclipse.wst.xml.core 0.0.0' but it could not be found [message #854123 is a reply to message #850919] Mon, 23 April 2012 17:35 Go to previous message
For 3.7 you should be using the Indigo site.
http://wiki.eclipse.org/WTP_FAQ#What_version_of_Eclipse_does_WTP_work_with.3F
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Previous Topic:The CellEditor can't editor
Next Topic:Debug function not working in Eclipse galilio
Current Time: Thu Jan 18 12:10:12 GMT 2018
Powered by FUDForum. Page generated in 0.01818 seconds
