Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » registering a time provider
registering a time provider [message #104984] Wed, 19 December 2007 14:45 Go to next message
Jean-Claude Cote is currently offline Jean-Claude Cote
Member
I'm working on an EMFT project called Temporality. This project focuses on
keeping a historical record of the state of modeled instances.
A central concept of this feature is the current date. I'd rather not hard
code access to the current time like this System.currentMilliseconds() but
rather hide access to the current time behind an interface and provide a way
to plug different time provider implementations.
That way I could have a testing time provider and a runtime etc.
What is the best way to plug this type of provider in EMF? The idea would be
to give developers a way to plug the implemenation of an interface. Can I
register such a class in an EPackage?
interface TemporalDate {
setNow(Date d);
Date now();
boolean areEqual(Date a, Date b, int granularity);
class RuntimeTemporalDate{
Date now(){
return new Date(System.currentMili);
class DebugTemporalDate{
Date now;
void setNow(Date d){
now = d;
Jean-Claude
Re: registering a time provider [message #104987 is a reply to message #104984] Wed, 19 December 2007 15:15 Go to previous messageGo to next message
Eclipse User
Jean-Claude,
I probably don't understand the overall design well enough to give sound
advice. It seems to me likely that things (operations on the model
instances) will be running in some type of context and that this context
would provide the time. Of course time changes as time passes, so it's
likely that such a context would describe a delta between the "virtual"
time (the time the context intends the operations to be interpreted
against) and the actual time on the process'/machine's clock. Perhaps a
resource set would have an adapter that would provide the context that
in turn provides the time (much like how an editing domain is associated
with the resource set). Then anyone can adapt it as they see fit...
jc wrote:
> setNow(Date d);
> Date now();
> Date now(){
> Date now;
> now = d;
> Thanks
> Jean-Claude
Re: registering a time provider [message #105003 is a reply to message #104987] Thu, 20 December 2007 14:55 Go to previous messageGo to next message
Member
Ed,
If I understand correct you would suggest to create an adapter factory that
adds a getNow() behavior to the EObjects.
I would then register this factory with the resource set. Using the
EcoreUtil.getRegisteredAdapter() method I could get this factory which would
provide me with the single adapter that provides the getNow() functionality.
I like the idea of registering with the resource set. As you say this would
enable anyone the ability to override this behavior.
Is there a way to register adapter factories with resource sets by using
extention points?
Also one issue I have is that it does force my EObjects to be in a resource
in order for the EcoreUtil.getRegisteredAdapter() to work. Correct?
Jean-Claude
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fkbu5i$1ha$1@build.eclipse.org...
> Jean-Claude,
> resource set would have an adapter that would provide the context that in
> turn provides the time (much like how an editing domain is associated with
> jc wrote:
>> on keeping a historical record of the state of modeled instances.
>> hard code access to the current time like this
>> System.currentMilliseconds() but rather hide access to the current time
>> behind an interface and provide a way to plug different time provider
>> implementations.
>> be to give developers a way to plug the implemenation of an interface.
>> Can I register such a class in an EPackage?
>> setNow(Date d);
>> Date now();
>> Date now(){
>> Date now;
>> now = d;
>> Thanks
>> Jean-Claude
Re: registering a time provider [message #105004 is a reply to message #105003] Thu, 20 December 2007 15:20 Go to previous messageGo to next message
Eclipse User
Originally posted by: stepper.sympedia.de
--------------060102070000050802070908
Hi Jean-Claude,
Although I don't know why you want to provide the time via adapters to
single objects I have an idea for objects without resource set: You
could attach the adapter to resources and objects as well and if you
query the time provider for an object you could walk up the containment
tree until you find an adapter with the provider. I hope I don't say
non-sense ;-)
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
jc schrieb:
> Ed,
> extention points?
> Thanks
> Jean-Claude
>> Jean-Claude,
>> jc wrote:
>>> Hi,
>>> implementations.
>>> setNow(Date d);
>>> Date now();
>>> Date now(){
>>> Date now;
>>> now = d;
>>> Thanks
>>> Jean-Claude
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Hi Jean-Claude,<br>
<br>
non-sense ;-)<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</a><br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</a><br>
<br>
<br>
jc schrieb:
<blockquote cite="mid:fkehao$a93$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
extention points?
Jean-Claude
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fkbu5i$1ha$1@build.eclipse.org">news:fkbu5i$1ha$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Jean-Claude,
jc wrote:
</pre>
<pre wrap="">Hi,
implementations.
setNow(Date d);
Date now();
Date now(){
Date now;
now = d;
Jean-Claude
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------060102070000050802070908--
Re: registering a time provider [message #105006 is a reply to message #105003] Thu, 20 December 2007 17:16 Go to previous messageGo to next message
Eclipse User
--------------090304050004010900080401
Jean-Claude,
Comments below.
jc wrote:
> Ed,
I was more thinking it would be on the resource set itself. The
resource set is also a Notifier and can also have adapters. Here's an
example of how we determine the editing domain for an EObject (in
AdapterFactoryEditingDomain):
static public EditingDomain getEditingDomainFor(EObject object)
Resource resource = object.eResource();
if (resource != null)
IEditingDomainProvider editingDomainProvider =
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc e,
IEditingDomainProvider.class);
if (editingDomainProvider != null)
return editingDomainProvider.getEditingDomain();
else
ResourceSet resourceSet = resource.getResourceSet();
if (resourceSet instanceof IEditingDomainProvider)
EditingDomain editingDomain =
((IEditingDomainProvider)resourceSet).getEditingDomain();
return editingDomain;
else if (resourceSet != null)
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc eSet,
return null;
> extention points?
No. I could imagine having a static method like the one above for
getting the time. If it fails to find an adapter on the resource or the
resource set, it could just use the system time...
Yes, that's true. I'm not sure it so good to require the object itself
to hold the adapter (since once there is an adapter, changes will fire
notifications and that definitely affects performance). Expecting the
adapter on the resource or the resource set itself is perhaps better...
> Thanks
> Jean-Claude
>> Jean-Claude,
>> jc wrote:
>>> Hi,
>>> implementations.
>>> setNow(Date d);
>>> Date now();
>>> Date now(){
>>> Date now;
>>> now = d;
>>> Thanks
>>> Jean-Claude
<html>
<head>
</head>
Jean-Claude,<br>
<br>
Comments below.<br>
<br>
<pre wrap="">Ed,
</pre>
</blockquote>
I was more thinking it would be on the resource set itself.&nbsp; The
resource set is also a Notifier and can also have adapters.&nbsp; Here's an
AdapterFactoryEditingDomain):<br>
<br>
<blockquote><small>&nbsp; static public EditingDomain
getEditingDomainFor(EObject object)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; Resource resource = object.eResource();<br>
&nbsp;&nbsp;&nbsp; if (resource != null)<br>
&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; IEditingDomainProvider editingDomainProvider =<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; (IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc e,
IEditingDomainProvider.class);<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (editingDomainProvider != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return editingDomainProvider.getEditingDomain();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; else<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; ResourceSet resourceSet = resource.getResourceSet();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (resourceSet instanceof IEditingDomainProvider)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; EditingDomain editingDomain =
((IEditingDomainProvider)resourceSet).getEditingDomain();<br >
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return editingDomain;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; else if (resourceSet != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; editingDomainProvider =
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (editingDomainProvider != null)<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return editingDomainProvider.getEditingDomain();<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }<br>
<br>
&nbsp;&nbsp;&nbsp; return null;<br>
&nbsp; }</small><br>
</blockquote>
<br>
<pre wrap="">I would then register this factory with the resource set. Using the
extention points?
</pre>
</blockquote>
No.&nbsp; I could imagine having a static method like the one above for
getting the time.&nbsp; If it fails to find an adapter on the resource or
the resource set, it could just use the system time...<br>
<pre wrap="">
</pre>
</blockquote>
Yes, that's true.&nbsp; I'm not sure it so good to require the object itself
notifications and that definitely affects performance).&nbsp; Expecting the
adapter on the resource or the resource set itself is perhaps better...<br>
<pre wrap="">
Jean-Claude
</pre>
jc wrote:
</pre>
<pre wrap="">Hi,
implementations.
setNow(Date d);
Date now();
Date now(){
Date now;
now = d;
Jean-Claude
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------090304050004010900080401--
Re: registering a time provider [message #105007 is a reply to message #105004] Thu, 20 December 2007 17:19 Go to previous messageGo to next message
Eclipse User
--------------020807000000040409060505
Eike,
Yes, I was thinking that would be the most flexible of all, i.e., check
the object, then the parent, until you get to the resource, then check
it, and finally the resource set. It's also relatively expensive to do
all this checking up the containment hierarchy, which is why I didn't
suggest it. I suppose an alternative would be to get the root object
(EcoreUtil.getRoot) and check it, then the resource and the resource set...
Eike Stepper wrote:
> Hi Jean-Claude,
> containment tree until you find an adapter with the provider. I hope I
> don't say non-sense ;-)
> Eike Stepper
> jc schrieb:
>> Ed,
>> extention points?
>> Thanks
>> Jean-Claude
>>> Jean-Claude,
>>> jc wrote:
>>>> Hi,
>>>> implementations.
>>>> setNow(Date d);
>>>> Date now();
>>>> Date now(){
>>>> Date now;
>>>> now = d;
>>>> Thanks
>>>> Jean-Claude
<html>
<head>
</head>
Eike,<br>
<br>
Re: registering a time provider [message #105009 is a reply to message #105003] Fri, 21 December 2007 00:30 Go to previous messageGo to next message
Eclipse User
--------------070309050704000500020202
Jean-Claude,
I remember that I commented on your proposal in the emft-dev list. Have
you already had the time to read these comments?
One of them seems a bit related to the question of where to attach your
time provider. The more objects are given the possibility to have their
own time (different from others) the more you introduce the possibility
to navigate an inconsistent object graph. Depending on your requirements
I suggest that you only attach one time provider to a whole resource
set. IMHO this is the only ay to make inter-resource cross references
consistently navigable.
I'd like to offer you again that we discuss how I solved the same issues
for my CDO technology (also EMFT). Among other things CDO also offers
support for time travelling through arbitrary object graphs and it could
eventually be possible that we were able to factor out a common
framework for cross-cutting model concerns like transparent versioning,
transparent persistence and the like.
Eike Stepper
jc schrieb:
> Ed,
> extention points?
> Thanks
> Jean-Claude
>> Jean-Claude,
>> jc wrote:
>>> Hi,
>>> implementations.
>>> setNow(Date d);
>>> Date now();
>>> Date now(){
>>> Date now;
>>> now = d;
>>> Thanks
>>> Jean-Claude
<html>
<head>
<title></title>
</head>
Jean-Claude,<br>
<br>
you already had the time to read these comments? <br>
<br>
requirements I suggest that you only attach one time provider to a
whole resource set. IMHO this is the only ay to make inter-resource
cross references consistently navigable.<br>
<br>
issues for my CDO technology (also EMFT). Among other things CDO also
offers support for time travelling through arbitrary object graphs and
it could eventually be possible that we were able to factor out a
common framework for cross-cutting model concerns like transparent
versioning, transparent persistence and the like.<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
<br>
<pre wrap="">Ed,
extention points?
Jean-Claude
</pre>
jc wrote:
</pre>
<pre wrap="">Hi,
implementations.
setNow(Date d);
Date now();
Date now(){
Date now;
now = d;
Jean-Claude
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------070309050704000500020202--
Re: registering a time provider [message #105012 is a reply to message #105009] Fri, 21 December 2007 08:59 Go to previous message
Member
------=_NextPart_000_0042_01C843AF.C1925670
charset="ISO-8859-15"
Eike,
Yes I want to only support one TimeProvider for all objects. But I want =
developers to be able to inject custom TimeProviders if only for =
testing.
So basically I want the concept of a registry where the temporality =
subsystem can retrieve the TimeProvider object from and where developers =
can put custom TimeProviers.
I understand the idea that the ResourceSet holds on to such a registry =
however I would like it if it where possible to use a registry even when =
the objects are not in a ResourceSet or there are no ResourceSet created =
yet.
There will be only one TimeProvider I just want a nice EMF friendly way =
to access it.
jc
"Eike Stepper" <stepper@sympedia.de> wrote in message =
news:fkfj1u$l9j$1@build.eclipse.org...
Jean-Claude,
I remember that I commented on your proposal in the emft-dev list. =
Have you already had the time to read these comments?=20
One of them seems a bit related to the question of where to attach =
your time provider. The more objects are given the possibility to have =
their own time (different from others) the more you introduce the =
possibility to navigate an inconsistent object graph. Depending on your =
requirements I suggest that you only attach one time provider to a whole =
resource set. IMHO this is the only ay to make inter-resource cross =
I'd like to offer you again that we discuss how I solved the same =
issues for my CDO technology (also EMFT). Among other things CDO also =
offers support for time travelling through arbitrary object graphs and =
it could eventually be possible that we were able to factor out a common =
framework for cross-cutting model concerns like transparent versioning, =
Eike Stepper
jc schrieb:=20
Ed,
If I understand correct you would suggest to create an adapter factory =
that=20
I would then register this factory with the resource set. Using the=20
EcoreUtil.getRegisteredAdapter() method I could get this factory which =
would=20
provide me with the single adapter that provides the getNow() =
functionality.
I like the idea of registering with the resource set. As you say this =
would=20
Is there a way to register adapter factories with resource sets by using =
extention points?
Also one issue I have is that it does force my EObjects to be in a =
resource=20
Jean-Claude
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Jean-Claude,
I probably don't understand the overall design well enough to give sound =
advice. It seems to me likely that things (operations on the model=20
instances) will be running in some type of context and that this context =
would provide the time. Of course time changes as time passes, so it's=20
likely that such a context would describe a delta between the "virtual"=20
time (the time the context intends the operations to be interpreted=20
against) and the actual time on the process'/machine's clock. Perhaps a =
resource set would have an adapter that would provide the context that =
in=20
turn provides the time (much like how an editing domain is associated =
with=20
jc wrote:
I'm working on an EMFT project called Temporality. This project focuses=20
A central concept of this feature is the current date. I'd rather not=20
hard code access to the current time like this=20
System.currentMilliseconds() but rather hide access to the current time=20
behind an interface and provide a way to plug different time provider=20
implementations.
What is the best way to plug this type of provider in EMF? The idea =
would=20
be to give developers a way to plug the implemenation of an interface.=20
setNow(Date d);
Date now();
Date now(){
Date now;
now =3D d;
Jean-Claude
=20
<HTML><HEAD><TITLE></TITLE>
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV>
<DIV>Eike,</DIV>
<DIV>&nbsp;</DIV>
<DIV>Yes I want to only support one TimeProvider for all objects. But I =
want=20
testing.</DIV>
<DIV>&nbsp;</DIV>
<DIV>So basically I want the concept of a registry where the temporality =
can put=20
custom TimeProviers.</DIV>
<DIV>&nbsp;</DIV>
<DIV>I understand the idea that the ResourceSet holds on to such a =
registry=20
the=20
yet.</DIV>
<DIV>&nbsp;</DIV>
<DIV>There will be only one TimeProvider I just want a nice EMF friendly =
way to=20
access it.</DIV>
<DIV>&nbsp;</DIV>
<DIV>Thanks</DIV>
<DIV>jc</DIV></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Eike Stepper" &lt;<A=20
href=3D"mailto:stepper@sympedia.de">stepper@sympedia.de</A>&gt; wrote =
in message=20
<A=20
href=3D"news:fkfj1u$l9j$1@build.eclipse.org">news:fkfj1u$l9j$1@build.ecli=
pse.org</A>...</DIV>Jean-Claude,<BR><BR>I=20
remember that I commented on your proposal in the emft-dev list. Have =
you=20
already had the time to read these comments? <BR><BR>One of them seems =
a bit=20
related to the question of where to attach your time provider. The =
more=20
objects are given the possibility to have their own time (different =
from=20
others) the more you introduce the possibility to navigate an =
inconsistent=20
object graph. Depending on your requirements I suggest that you only =
attach=20
one time provider to a whole resource set. IMHO this is the only ay to =
make=20
inter-resource cross references consistently navigable.<BR><BR>I'd =
like to=20
offer you again that we discuss how I solved the same issues for my =
CDO=20
technology (also EMFT). Among other things CDO also offers support for =
time=20
travelling through arbitrary object graphs and it could eventually be =
possible=20
that we were able to factor out a common framework for cross-cutting =
model=20
concerns like transparent versioning, transparent persistence and the=20
like.<BR><BR>Regards,<BR>Eike Stepper<BR>----<BR><A=20
class=3Dmoz-txt-link-freetext=20
href=3D"http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</A><BR><=
A=20
href=3D"http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</A><=
BR><BR><BR><BR>jc=20
schrieb:=20
<BLOCKQUOTE cite=3Dmid:fkehao$a93$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Ed,
that=20
would=20
functionality.
would=20
extention points?
resource=20
Jean-Claude
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fkbu5i$1ha$1@build.eclipse.org">news:fkbu5i$1ha$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Jean-Claude,
in=20
with=20
jc wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
implementations.
would=20
setNow(Date d);
Date now();
Date now(){
Date now;
now =3D d;
Jean-Claude
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0042_01C843AF.C1925670--
Re: registering a time provider [message #612914 is a reply to message #104984] Wed, 19 December 2007 15:15 Go to previous message
Ed Merks is currently offline Ed Merks
Jean-Claude,
jc wrote:
> setNow(Date d);
> Date now();
> Date now(){
> Date now;
> now = d;
> Thanks
> Jean-Claude
Re: registering a time provider [message #612930 is a reply to message #104987] Thu, 20 December 2007 14:55 Go to previous message
Member
Ed,
extention points?
Jean-Claude
> Jean-Claude,
> jc wrote:
>> implementations.
>> setNow(Date d);
>> Date now();
>> Date now(){
>> Date now;
>> now = d;
>> Thanks
>> Jean-Claude
Re: registering a time provider [message #612932 is a reply to message #105003] Thu, 20 December 2007 15:20 Go to previous message
Eike Stepper is currently offline Eike Stepper
Hi Jean-Claude,
non-sense ;-)
Eike Stepper
jc schrieb:
> Ed,
> extention points?
> Thanks
> Jean-Claude
>> Jean-Claude,
>> jc wrote:
>>> Hi,
>>> implementations.
>>> setNow(Date d);
>>> Date now();
>>> Date now(){
>>> Date now;
>>> now = d;
>>> Thanks
>>> Jean-Claude
<html>
<head>
<title></title>
</head>
Hi Jean-Claude,<br>
<br>
non-sense ;-)<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
<pre wrap="">Ed,
extention points?
Jean-Claude
</pre>
jc wrote:
</pre>
<pre wrap="">Hi,
implementations.
setNow(Date d);
Date now();
Date now(){
Date now;
now = d;
Jean-Claude
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: registering a time provider [message #612936 is a reply to message #105003] Thu, 20 December 2007 17:16 Go to previous message
Jean-Claude,
Comments below.
jc wrote:
> Ed,
else
return null;
> extention points?
> Thanks
> Jean-Claude
>> Jean-Claude,
>> jc wrote:
>>> Hi,
>>> implementations.
>>> setNow(Date d);
>>> Date now();
>>> Date now(){
>>> Date now;
>>> now = d;
>>> Thanks
>>> Jean-Claude
<html>
<head>
</head>
Jean-Claude,<br>
<br>
Comments below.<br>
<br>
<pre wrap="">Ed,
</pre>
</blockquote>
<br>
&nbsp; {<br>
<br>
</blockquote>
<br>
extention points?
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
Jean-Claude
</pre>
jc wrote:
</pre>
<pre wrap="">Hi,
implementations.
setNow(Date d);
Date now();
Date now(){
Date now;
now = d;
Jean-Claude
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: registering a time provider [message #612938 is a reply to message #105004] Thu, 20 December 2007 17:19 Go to previous message
Eike,
Eike Stepper wrote:
> Hi Jean-Claude,
> Eike Stepper
> jc schrieb:
>> Ed,
>> extention points?
>> Thanks
>> Jean-Claude
>>> Jean-Claude,
>>> jc wrote:
>>>> Hi,
>>>> implementations.
>>>> setNow(Date d);
>>>> Date now();
>>>> Date now(){
>>>> Date now;
>>>> now = d;
>>>> Thanks
>>>> Jean-Claude
<html>
<head>
</head>
Eike,<br>
<br>
Re: registering a time provider [message #612943 is a reply to message #105003] Fri, 21 December 2007 00:30 Go to previous message
Jean-Claude,
Eike Stepper
jc schrieb:
> Ed,
> extention points?
> Thanks
> Jean-Claude
>> Jean-Claude,
>> jc wrote:
>>> Hi,
>>> implementations.
>>> setNow(Date d);
>>> Date now();
>>> Date now(){
>>> Date now;
>>> now = d;
>>> Thanks
>>> Jean-Claude
<html>
<head>
<title></title>
</head>
Jean-Claude,<br>
<br>
<br>
<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
<br>
<pre wrap="">Ed,
extention points?
Jean-Claude
</pre>
jc wrote:
</pre>
<pre wrap="">Hi,
implementations.
setNow(Date d);
Date now();
Date now(){
Date now;
now = d;
Jean-Claude
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: registering a time provider [message #612949 is a reply to message #105009] Fri, 21 December 2007 08:59 Go to previous message
Member
Eike,
testing.
yet.
to access it.
jc
Jean-Claude,
Eike Stepper
jc schrieb:=20
Ed,
that=20
would=20
functionality.
would=20
extention points?
resource=20
Jean-Claude
Jean-Claude,
in=20
with=20
implementations.
would=20
setNow(Date d);
Date now();
Date now(){
Date now;
now =3D d;
Jean-Claude
=20
<STYLE></STYLE>
</HEAD>
<DIV>
<DIV>Eike,</DIV>
<DIV>&nbsp;</DIV>
want=20
testing.</DIV>
<DIV>&nbsp;</DIV>
can put=20
<DIV>&nbsp;</DIV>
registry=20
the=20
yet.</DIV>
<DIV>&nbsp;</DIV>
way to=20
access it.</DIV>
<DIV>&nbsp;</DIV>
<DIV>Thanks</DIV>
<DIV>jc</DIV></DIV>
in message=20
<A=20
you=20
a bit=20
more=20
from=20
inconsistent=20
attach=20
make=20
like to=20
CDO=20
time=20
possible=20
model=20
A=20
schrieb:=20
that=20
would=20
functionality.
would=20
extention points?
resource=20
Jean-Claude
message=20
pse.org</A>...
</PRE>
in=20
with=20
jc wrote:
</PRE>
implementations.
would=20
setNow(Date d);
Date now();
Date now(){
Date now;
now =3D d;
Jean-Claude
Previous Topic:[CDO][0.8.0] TypeManager
Next Topic:[Temporality] Temporality design
Current Time: Tue Oct 08 08:02:26 EDT 2013
Powered by FUDForum. Page generated in 0.02361 seconds
