| How to register a Xcore model ? [message #837468] |
Thu, 05 April 2012 13:58  |
Cristiano Gaviao Messages: 247 Registered: July 2009 |
In EMF projects we use the org.eclipse.emf.ecore.generated_package extension point to register packages from models:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www.xtext.org/example/Domainmodel"
class = "org.eclipse.xtext.example.domainmodel.domainmodel.DomainmodelPackage"
genModel = "org/eclipse/xtext/example/domainmodel/Domainmodel.genmodel" />
</extension>
How could I do that with Xcore models ?
regards,
Cristiano
| Re: How to register a Xcore model ? [message #837824 is a reply to message #837468] |
Fri, 06 April 2012 02:17  |
Ed Merks Messages: 24550 Registered: July 2009 |
Christiano,
Comments below.
On 05/04/2012 7:58 PM, Cristiano Gaviao wrote:
> <package uri = "http://www.xtext.org/example/Domainmodel"
> class =
> genModel =
> </extension>
The generator does already generate registrations, but it's for the
Xcore resource, which does contain a GenModel, so should be fine. I
think it probably doesn't work though because the registration doesn't
indicate which offset within the resource contains the GenModel. Please
open a bugzilla so you can track the fix for that.
> regards,
> Cristiano
FUDForum. Page generated in 0.02630 seconds
