Home » Eclipse Projects » BIRT » BIRT and SQL 2008 R2(Difference between SQL 2005 and 2008 R2)
BIRT and SQL 2008 R2 [message #836671] Wed, 04 April 2012 19:28 Go to next message
Perry Smith is currently offline Perry SmithFriend
using BIRT 3.7.2 and Microsoft SQL Server JDBC Driver 4.0, data source connection tests for SQL 2005 and 2008 R2 both appear to be positive. But, when I open the editor for 2008 R2 data sets, in the Query section. I do not see all of the schemas I do when I am viewing the same for SQL 2005, only the main connection node. No data is returned. This message appears in details. What can I do to et BIRT working with 2008 R2?
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:135)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.runDataset(DatasetPreviewTask.java:97)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.execute(DatasetPreviewTask.java:49)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetPreviewer.preview(DataSetPreviewer.java:69)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPreviewPage$5.run(ResultSetPreviewPage.java:337)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1:The connection is closed.
com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.doGetMetaData(PreparedStatement.java:347)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:563)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:927)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:428)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1134)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultMetaData(QueryResults.java:132)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.extractQuery(DatasetPreviewTask.java:169)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:126)
... 5 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:464)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingDefaultPolicy(Statement.java:371)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:313)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:412)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:379)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 16 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.checkClosed(SQLServerConnection.java:388)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.checkClosed(SQLServerStatement.java:978)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:284)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:460)
... 22 more
Re: BIRT and SQL 2008 R2 [message #837442 is a reply to message #836671] Thu, 05 April 2012 17:07 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Can you try the JTDS driver as described in this bug?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298730
Jason
> running the report.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 5 more
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
> at
> at
> at
> at
> at
> ... 22 more
Re: BIRT and SQL 2008 R2 [message #838090 is a reply to message #837442] Fri, 06 April 2012 14:49 Go to previous messageGo to next message
When I test connection using net.sourceforge.jtds.jdbc.Driver (v1.1), this message appears;
"The selected driver cannot parse the given url."
org.eclipse.birt.report.data.oda.jdbc.JDBCException: The selected driver cannot parse the given url.
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.testConnection(JDBCDriverManager.java:696)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:147)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:175)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:156)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.testConnection(JDBCSelectionPageHelper.java:715)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.access$7(JDBCSelectionPageHelper.java:683)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper$7.widgetSelected(JDBCSelectionPageHelper.java:606)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.actions.EditDataSourceAction.doAction(EditDataSourceAction.java:69)
at org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: BIRT and SQL 2008 R2 [message #840040 is a reply to message #838090] Mon, 09 April 2012 15:38 Go to previous messageGo to next message
Did you change the url to look like:
jdbc:jtds:sqlserver://server:port/dbname?
Jason
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Re: BIRT and SQL 2008 R2 [message #840042 is a reply to message #838090] Mon, 09 April 2012 15:42 Go to previous messageGo to next message
Using this example from the link you provided as my guide, jdbc:jtds:sqlserver://shanghai:1433/test , I am able to connect to one form of Database URL but not another. The first successful connection test to a 2008 R2 DB looks like this jdbc:jtds:sqlserver://shanghai:1433;databaseName = Name
What does not work is my reference to a sub-instance; jdbc:jtds:sqlserver://shanghai\SQL1;databaseName=Name
I assume this is because I don't know what the syntax should be for jtds in this instance. The last 3 connections I need to establish are jdbc:jtds:sqlserver://shanghai\SQL1;databaseName=Name, jdbc:jtds:sqlserver://shanghai\SQL2:port;databaseName=Name, jdbc:jtds:sqlserver://shanghai\SQL3;databaseName=Name
Suggestions?
Re: BIRT and SQL 2008 R2 [message #840088 is a reply to message #840042] Mon, 09 April 2012 16:37 Go to previous messageGo to next message
Have you seen this:
http://confluence.atlassian.com/display/JIRA/Connecting+to+named+instances+in+SQL+Server
Jason
> Suggestions?
Re: BIRT and SQL 2008 R2 [message #840165 is a reply to message #840088] Mon, 09 April 2012 18:54 Go to previous message
Thank you!
That last link got me through it.
Previous Topic:Debugging BIRT query
Next Topic:Table inside a Grid (pagination problem)
Current Time: Wed May 23 18:57:22 GMT 2018
Powered by FUDForum. Page generated in 0.02608 seconds
