Home » Eclipse Projects » Eclipse Platform » propertyTester for perspective in visibleWhen expression
propertyTester for perspective in visibleWhen expression [message #834912] Mon, 02 April 2012 14:47 Go to next message
Christian Pontesegger is currently offline Christian PonteseggerFriend
I was playing around with the expression framework as this is a topic I avoided to touch for too long. I tried to find a very simple example. Therefore I added a toolbar with some sample commands. One uses following visibleWhen expression:
            <command
                  commandId="org.eclipse.ui.file.exit"
                  label="Test4"
                  style="push">
               <visibleWhen
                     checkEnabled="false">
                  <with
                        variable="activeWorkbenchWindow">
                     <test
                           property="org.eclipse.ui.workbenchWindow.isPerspectiveOpen">
                     </test>
                  </with>
               </visibleWhen>
            </command>
I thought this will hide the button when no perspective is open. Unfortunately it doesn't. The button remains visible after closing the last open perspective. Am I facing a bug here or am I using the expression in a wrong way?
thanks
Re: propertyTester for perspective in visibleWhen expression [message #835449 is a reply to message #834912] Tue, 03 April 2012 08:27 Go to previous message
Libor Jelinek is currently offline Libor JelinekFriend
Hello Christian,
your code looks like valid but try bellow if it helps:
1) Remove checkEnabled="false". I've never used it before and not sure what is true purpose of it.
2) Rewrite condition from test to equals
<with variable="activeWorkbenchWindowActivePerspectiveName">
   <equals value=""/>
   <!-- or if you -->
   <not>
      <equals value="id.of.your.only.perspective"/>
   </not>
</with>
See ISources.ACTIVE_WORKBENCH_WINDOW_ACTIVE_PERSPECTIVE_NAME
3) If everything else failed, turn on tracing options
Hope that helps!
Previous Topic:Launching DOJO based Static Web Page from RCP App
Next Topic:Touch-typing: How to avoid using the mouse in Eclipse
Current Time: Sun Feb 25 02:09:13 GMT 2018
Powered by FUDForum. Page generated in 0.01869 seconds
