Home » Eclipse Projects » Web Tools Project (WTP) » IWAB0234E occured when trying Bottom Up Web Service Supporting Flexible Projects
IWAB0234E occured when trying Bottom Up Web Service Supporting Flexible Projects [message #104056] Sun, 15 May 2005 10:30 Go to next message
Eclipse User
Originally posted by: sinbadblue.gmail.com
I downloaded the all-in-one zip: wtp-eclipse-emf-gef-jem-sdk-1.0M4.zip
jdk is 1.4.2
tomcat 5.0.28
when I trying the tutorial, the error occured at:
click Next at Object Selection Page
anyone else meet the error? or who can help me ?
Re: IWAB0234E occured when trying Bottom Up Web Service Supporting Flexible Projects [message #104119 is a reply to message #104056] Sun, 15 May 2005 15:07 Go to previous messageGo to next message
Lawrence Mandel is currently offline Lawrence Mandel
Which tutorial are you working through?
Exactly what step is producing the error?
What error message do you see?
Lawrence
>jdk is 1.4.2
>tomcat 5.0.28
Re: IWAB0234E occured when trying Bottom Up Web Service Supporting Flexible Projects [message #104187 is a reply to message #104119] Mon, 16 May 2005 09:28 Go to previous messageGo to next message
Eclipse User
I'm sorry, perhaps I shouldn't type the name of tutorial in the title.
"Bottom Up Web Service Supporting Flexible Projects"
http://www.eclipse.org/webtools/jst/components/ws/M4/tutoria ls/BottomUpWebService.html
Section :"Creating a bottom up Java bean Web service and Web service client"
's step #10
step 9 is ok , I see the window: Object Selection Page
then click Next , the error occurred.
error message? I think the exception track is too long. So I just post the
error id: IWAB0234E.
If you're sure that the exception debug track can be helpful. Then, tell me
please. I'll post the long track. Thanks
<lmandel@ca.ibm.com> ??????:d686m4$ri$1@news.eclipse.org...
> Lawrence
>>jdk is 1.4.2
>>tomcat 5.0.28
Re: IWAB0234E occured when trying Bottom Up Web Service Supporting Flexible Projects [message #108401 is a reply to message #104187] Tue, 31 May 2005 16:18 Go to previous messageGo to next message
Todd Hill is currently offline Todd Hill
I had a similar problemt:
I was working through the tutorial titled "Bottom Up Web Service Supporting
Flexible Projects" and received the following error after pressing "FINISH"
(step 12 of the tutorial).
IWAB0014E Unexpected exception occured.
null
java.lang.NoClassDefFoundError
at org.apache.axis.client.Service.getAxisClient(Service.java:14 3)
at org.apache.axis.client.Service.<init>(Service.java:152)
at org.apache.axis.client.AdminClient.<init>(AdminClient.java:157)
org.apache.axis.tools.ant.axis.AdminClientTask.execute(Admin ClientTask.java:305)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ax isDeployCommand.executeAntTask(AxisDeployCommand.java:111)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ax isDeployCommand.execute(AxisDeployCommand.java:72)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:335)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:301)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:217)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$4.run(SimpleCommandEngineManager.java:208)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:177)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:80)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:220)
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:333)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
"Sinbadblue.Kong" <sinbadblue@gmail.com> wrote in message
news:d6a7nt$q6u$1@news.eclipse.org...
> client" 's step #10
> me please. I'll post the long track. Thanks
>> Thanks,
>> Lawrence
>>>jdk is 1.4.2
>>>tomcat 5.0.28
Re: IWAB0234E occured when trying Bottom Up Web Service Supporting Flexible Projects [message #108415 is a reply to message #104187] Tue, 31 May 2005 16:36 Go to previous message
Just duplicated the same error message. Here is the stacktrace:
IWAB0234E An internal error occurred. Details: null
org.eclipse.jst.ws.internal.consumption.ui.common.ServerSele ctionUtils.getCompatibleExistingServers(ServerSelectionUtils .java:337)
org.eclipse.jst.ws.internal.consumption.ui.widgets.runtime.C lientRuntimeSelectionWidgetDefaultingCommand.setClientDefaul tServer(ClientRuntimeSelectionWidgetDefaultingCommand.java:7 13)
org.eclipse.jst.ws.internal.consumption.ui.widgets.runtime.C lientRuntimeSelectionWidgetDefaultingCommand.execute(ClientR untimeSelectionWidgetDefaultingCommand.java:194)
org.eclipse.jst.ws.internal.creation.ui.widgets.runtime.Serv erRuntimeSelectionWidgetDefaultingCommand.execute(ServerRunt imeSelectionWidgetDefaultingCommand.java:78)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:119)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:120)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:747)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:123)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
> client" 's step #10
>> Thanks,
>> Lawrence
>>>jdk is 1.4.2
>>>tomcat 5.0.28
Previous Topic:IWAB0398E Error in generating WSDL from Java
Next Topic:Access UDDI regestry
Current Time: Wed May 22 04:27:30 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
