Home » Eclipse Projects » WindowBuilder » Errors while installing under Ubuntu 11.10
Errors while installing under Ubuntu 11.10 [message #829063] Sun, 25 March 2012 20:20 Go to next message
Martin Esser is currently offline Martin EsserFriend
Hi!
I tried to install WindowBuilder in Eclipse 3.7.0 via "Help->Install New Software ..." with this link: "//download.eclipse.org/windowbuilder/WB/release/R201106211200/3.7/"
Unfortunately I receive the following errors:
Cannot complete the install because one or more required items could not be found.
Software being installed: WindowBuilder XML Core 1.0.0.r37x201106081533 (org.eclipse.wb.core.xml.feature.feature.group 1.0.0.r37x201106081533)
Missing requirement: WindowBuilder Core for XML GUI's 1.0.0.r37x201106081533 (org.eclipse.wb.core.xml 1.0.0.r37x201106081533) requires 'bundle org.eclipse.wst.sse.core 0.0.0' but it could not be found
Cannot satisfy dependency:
From: WindowBuilder XML Core 1.0.0.r37x201106081533 (org.eclipse.wb.core.xml.feature.feature.group 1.0.0.r37x201106081533)
To: org.eclipse.wb.core.xml [1.0.0.r37x201106081533]
I can't figure out what's going wrong.
Any help?
Thanks, Martin.
Re: Errors while installing under Ubuntu 11.10 [message #831587 is a reply to message #829063] Thu, 29 March 2012 04:22 Go to previous messageGo to next message
Bob Sadarka is currently offline Bob SadarkaFriend
Member
I installed WB successfully from that URL, maybe the server was down for sometimes. Try again later.
Re: Errors while installing under Ubuntu 11.10 [message #835903 is a reply to message #831587] Tue, 03 April 2012 20:43 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
I woud also recommend installing the latest build and not the older 1.0.0.x build.
Re: Errors while installing under Ubuntu 11.10 [message #835932 is a reply to message #835903] Tue, 03 April 2012 21:38 Go to previous message
Problem solved!
Solution: I selected the core stuff only at the first attempt; then the rest. That did the trick for me.
Thanks anyway ...
Previous Topic:Layout Manager
Next Topic:Instance factory implementation for newly created custom component plugin
Current Time: Tue Jan 16 11:55:39 GMT 2018
Powered by FUDForum. Page generated in 0.02071 seconds
