Home » Eclipse Projects » Eclipse Platform » Common Navigator Framework - plugin extension
Common Navigator Framework - plugin extension [message #827563] Fri, 23 March 2012 14:03
Bartosz Popiela is currently offline Bartosz PopielaFriend
I'm using Common Navigator Framework and I'd like it to use my custom label provider. I created a new plugin project containing my custom label provider class and set extension in plugin.xml to org.eclipse.ui.navigator.navigatorContent extension point from org.eclipse.ui.navigator plugin. I added navigatorContent element, set name, id and labelProvider to my own class.
This doesn't work. My custom label provider isn't created.
What am I doing wrong?
These both plugins are linked to my main plugin, running Eclipse RCP application.
Edit: problem solved.
[Updated on: Wed, 28 March 2012 09:43]
Report message to a moderator
Previous Topic:update site build
Next Topic:error with adb
Current Time: Wed Feb 21 15:57:02 GMT 2018
Powered by FUDForum. Page generated in 0.03466 seconds
