Home » Eclipse Projects » Web Tools Project (WTP) » Content assist for taglibs not working in JSP editor
Content assist for taglibs not working in JSP editor [message #827544] Fri, 23 March 2012 09:28 Go to next message
Dirk Roesler is currently offline Dirk Roesler
The content assist for taglibs in the JSP editor is no longer working. After pressing Ctrl+Space no suggestions are shown. Instead I found an exception in the log files:
!ENTRY org.eclipse.wst.xml.core 4 4 2012-03-23 14:24:44.034
!MESSAGE Error occurred while firing Node Parsed event
!STACK 0
	at org.eclipse.jst.jsp.core.taglib.ProjectDescription.updateWebXML(ProjectDescription.java:2574)
	at org.eclipse.jst.jsp.core.taglib.ProjectDescription$Indexer.visit(ProjectDescription.java:227)
	at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65)
	at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
	at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
	at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
	at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75)
	at org.eclipse.jst.jsp.core.taglib.ProjectDescription.index(ProjectDescription.java:1463)
	at org.eclipse.jst.jsp.core.taglib.ProjectDescription.restoreReferences(ProjectDescription.java:1909)
	at org.eclipse.jst.jsp.core.taglib.ProjectDescription.<init>(ProjectDescription.java:708)
	at org.eclipse.jst.jsp.core.taglib.TaglibIndex.createDescription(TaglibIndex.java:719)
	at org.eclipse.jst.jsp.core.taglib.TaglibIndex.internalResolve(TaglibIndex.java:899)
	at org.eclipse.jst.jsp.core.taglib.TaglibIndex.resolve(TaglibIndex.java:540)
	at org.eclipse.jst.jsp.core.internal.contentmodel.tld.TLDCMDocumentManager.getCacheKey(TLDCMDocumentManager.java:686)
	at org.eclipse.jst.jsp.core.internal.contentmodel.tld.TLDCMDocumentManager.getCMDocument(TLDCMDocumentManager.java:701)
	at org.eclipse.jst.jsp.core.internal.contentmodel.tld.TLDCMDocumentManager$DirectiveStructuredDocumentRegionHandler.enableTags(TLDCMDocumentManager.java:121)
	at org.eclipse.jst.jsp.core.internal.contentmodel.tld.TLDCMDocumentManager$DirectiveStructuredDocumentRegionHandler.processXMLStartTag(TLDCMDocumentManager.java:345)
	at org.eclipse.jst.jsp.core.internal.contentmodel.tld.TLDCMDocumentManager$DirectiveStructuredDocumentRegionHandler.processRegionCollection(TLDCMDocumentManager.java:182)
	at org.eclipse.jst.jsp.core.internal.contentmodel.tld.TLDCMDocumentManager$DirectiveStructuredDocumentRegionHandler.nodeParsed(TLDCMDocumentManager.java:191)
	at org.eclipse.wst.xml.core.internal.parser.XMLSourceParser.fireNodeParsed(XMLSourceParser.java:135)
	at org.eclipse.jst.jsp.core.internal.parser.JSPSourceParser.parseNodes(JSPSourceParser.java:296)
	at org.eclipse.wst.xml.core.internal.parser.XMLSourceParser.getDocumentRegions(XMLSourceParser.java:173)
	at org.eclipse.wst.sse.core.internal.text.StructuredDocumentReParser._core_reparse_text(StructuredDocumentReParser.java:355)
	at org.eclipse.wst.sse.core.internal.text.StructuredDocumentReParser.core_reparse(StructuredDocumentReParser.java:752)
	at org.eclipse.jst.jsp.core.internal.parser.JSPReParser.reparse(JSPReParser.java:153)
	at org.eclipse.wst.sse.core.internal.text.StructuredDocumentReParser.reparse(StructuredDocumentReParser.java:1333)
	at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocument.updateModel(BasicStructuredDocument.java:2713)
	at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocument.internalReplaceText(BasicStructuredDocument.java:1923)
	at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocument.replaceText(BasicStructuredDocument.java:2423)
	at org.eclipse.wst.sse.core.internal.text.BasicStructuredDocument.set(BasicStructuredDocument.java:2935)
	at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer.setDocumentContent(ResourceTextFileBuffer.java:575)
	at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer.initializeFileBufferContent(ResourceTextFileBuffer.java:286)
	at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.create(ResourceFileBuffer.java:245)
	at org.eclipse.core.internal.filebuffers.TextFileBufferManager.connect(TextFileBufferManager.java:112)
	at org.eclipse.ui.editors.text.TextFileDocumentProvider.createFileInfo(TextFileDocumentProvider.java:559)
	at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect(TextFileDocumentProvider.java:478)
	at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4213)
	at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:237)
	at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1451)
	at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:169)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(StructuredTextEditor.java:1918)
	at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3200)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
	at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2649)
	at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3218)
	at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3245)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredTextEditor.java:2595)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Any idea is appreciated.
Dirk
Re: Content assist for taglibs not working in JSP editor [message #829392 is a reply to message #827544] Mon, 26 March 2012 04:19 Go to previous messageGo to next message
Bob Sadarka is currently offline Bob Sadarka
Member
From the stack trace, it looks like that Eclipse was unable to update web.xml file. So check your web.xml if there is something wrong there.
Re: Content assist for taglibs not working in JSP editor [message #829458 is a reply to message #829392] Mon, 26 March 2012 06:09 Go to previous messageGo to next message
The web.xml looks fine, also no problems when running with Tomcat. It is a Maven project and the web.xml is located at "src\main\webapp\WEB-INF". Is it possible that Eclipse can't find it there? However everything worked fine for some time but I can't tell since when it is broken, maybe since the last WTP update.
Re: Content assist for taglibs not working in JSP editor [message #830642 is a reply to message #827544] Tue, 27 March 2012 18:53 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> !STACK 0
> java.lang.NullPointerException
> at
Does your web.xml refer to a tld file with a path that's only valid when
Maven puts everything together, and are you using WTP without the Maven
support?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Content assist for taglibs not working in JSP editor [message #830645 is a reply to message #830642] Tue, 27 March 2012 18:57 Go to previous message
Regardless, that exception should not be happening. Please open a bug
report at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20Source%20Editing&component=jst.jsp
and be sure to indicate which WTP version you're using (if in doubt,
check
http://wiki.eclipse.org/WTP_FAQ#What_version_of_Eclipse_does_WTP_work_with.3F).
Nitin Dahyabhai
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:JSP isErrorPage=&quot;true&quot; validation
Next Topic:Programatically Creating Deployment Descriptor
Current Time: Sun May 19 20:56:38 EDT 2013
Powered by FUDForum. Page generated in 0.01731 seconds
