Home » Language IDEs » ServerTools (WTP) » HTTP request after server startup
HTTP request after server startup [message #827281] Fri, 23 March 2012 05:16 Go to next message
Brett Randall is currently offline Brett RandallFriend
It appears to me like WTP may be sending a (test?) HTTP request to my server after launch is complete. I'm using Tomcat with Eclipse Web Developer Tools version 3.3.1.v201107072200-7O7IFhREMiB5vNoYqf01XHTvUndyz-yx-9kUyXXL
Build id: 20100921193530. My questions are:
* Is it true that WTP sends a test/probe HTTP request to the server after launch?
* Is this documented anywhere?
* Is there any configuration associated with this, can it be disabled?
Brett
Re: HTTP request after server startup [message #827413 is a reply to message #827281] Fri, 23 March 2012 09:48 Go to previous messageGo to next message
Bob Sadarka is currently offline Bob SadarkaFriend
Member
Brett Randall wrote on Fri, 23 March 2012 01:16
Brett
What's your evidence show that WTP is sending a HTTP test request? as far as I know, there is no automatic HTTP request after the server is launched.
Re: HTTP request after server startup [message #827591 is a reply to message #827281] Fri, 23 March 2012 14:37 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
> after launch?
> Thanks
> Brett
There is a "ping" test that makes a request to the server to see if a
connection can be established. This is how WTP determines if Tomcat has
reached the "Started" state.
Larry
Re: HTTP request after server startup [message #828037 is a reply to message #827413] Sat, 24 March 2012 05:12 Go to previous messageGo to next message
Apologies, I left those observations out in my original post:
* I have some new-Session logging in my app, which is being triggered on startup from Eclipse with no local or remote web browser connections.
* I can trap the connection with a breakpoint.
* The connection has User-Agent request header Java/1.6.0_30, and netstat on the machine shows it comes from the Eclipse JVM to the Tomcat JVM.
Brett
Re: HTTP request after server startup [message #828062 is a reply to message #827591] Sat, 24 March 2012 06:05 Go to previous messageGo to next message
Thanks Larry.
My interest here is when testing a webapp, and one is interested in observing behaviour on the very first request to the application, and having control over that request - parameters etc.
I take it that the request is currently a hard-coded GET to http ://<hostname>:<port>/ ? Would it be feasible to open this to end-user configuration? I appreciate that it might be difficult to allow it to be turned-off altogether, as to your point WTP won't know when the server has finished loading. But my tests for Tomcat at least suggest that I can send a request such as GET /foo/bar and expect a 404, and the 404 will only be delivered once the server is fully-started.
So if I was able to configure/customise the ping URL, and perhaps convince WTP to accept a 404 (not sure what it does with status codes now), then this would help with the above requirement. Aside: the current test-request does follow 301 redirects.
Does this have a chance of gaining support as an enhancement request?
Best
Brett
Re: HTTP request after server startup [message #838079 is a reply to message #828062] Fri, 06 April 2012 14:36 Go to previous messageGo to next message
On 3/24/2012 2:05 AM, Brett Randall wrote:
> Thanks Larry.
> Best
> Brett
Sorry to take so long to respond. I believe the current behavior is to
simply wait for a connection. I don't think it currently checks the
response in any way. You are welcome to enter a Bugzilla enhancement
request. Since my cycles available for WTP these days are pretty
limited, it would very likely need a patch to get the feature added.
Default behavior would be the same as the current behavior.
Larry
Re: HTTP request after server startup [message #846470 is a reply to message #827281] Mon, 16 April 2012 04:54 Go to previous message
Thanks, logged-as issue 376836 .
Previous Topic:Correct Pattern for contributing Outline Page
Next Topic:Unmarshall Error
Current Time: Sun May 20 12:21:16 GMT 2018
Powered by FUDForum. Page generated in 0.02450 seconds
