Home » Archived » Visual Editor (VE) » Bound text fields to database
Bound text fields to database [message #102123] Sat, 13 August 2005 19:27 Go to next message
Jose is currently offline JoseFriend
Member
Hi all
Using Ve, is thre a way to declare bound text fields, combo boxes, list
boxes, etc to the database?
Is there a way to boud a from to a table in a database?
Is there a way to create connection, datasets, datasources, recordsets,
commands, in the editor?
Will those functionalities be availabel in the enxt verions?
thanks
jsn
Re: Bound text fields to database [message #102213 is a reply to message #102123] Mon, 15 August 2005 14:58 Go to previous messageGo to next message
Dave Orme is currently offline Dave OrmeFriend
Jose wrote:
> Hi all
We're working with the JFace team on this. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104570
The early access code is available in:
Server: dev.eclipse.org
CVSroot: /home/tools
Project: org.eclipse.ve.sweet
There are demo/test programs in org.eclipse.ve.sweet.test and
org.eclipse.ve.sweet.table.test.
NOTE: This is totally unstable API right now! It's guaranteed to
change! But if you want to help us build the future of Eclipse user
interfaces, come join us!
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: Bound text fields to database [message #102231 is a reply to message #102123] Mon, 15 August 2005 15:59 Go to previous messageGo to next message
Gili Mendel is currently offline Gili MendelFriend
Jose wrote:
> Hi all
> thanks
> jsn
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=104570
Re: Bound text fields to database [message #102304 is a reply to message #102123] Tue, 16 August 2005 02:34 Go to previous message
Member
Excellent!!!!!
Re: Bound text fields to database [message #610274 is a reply to message #102123] Mon, 15 August 2005 14:58 Go to previous message
Jose wrote:
> Hi all
Dave Orme
Re: Bound text fields to database [message #610278 is a reply to message #102123] Mon, 15 August 2005 15:59 Go to previous message
Jose wrote:
> Hi all
> thanks
> jsn
Re: Bound text fields to database [message #610295 is a reply to message #102123] Tue, 16 August 2005 02:34 Go to previous message
Member
Excellent!!!!!
Previous Topic:Error Compiling using javac vs. Eclipise
Next Topic:VE After Upgrade throws exception on open
Current Time: Tue Jun 19 01:17:09 GMT 2018
Powered by FUDForum. Page generated in 0.03256 seconds
