Home » Eclipse Projects » BIRT » Building the designer, Nullpointer in DEUtil.java
Building the designer, Nullpointer in DEUtil.java [message #824922] Tue, 20 March 2012 08:39 Go to next message
hage Mising name is currently offline hage Mising nameFriend
Member
Hi there,
i checked out the resources via eclipse cvs plugin, and build the designer successfully with the export wizard from the .product-file. The build is successfull and the designer starts on my ubuntu. Clicking the "new" button, selecting the "Report"-entry and clicking "Next>" will generate a NullPointerException in DEUtil like this:
	at org.eclipse.core.internal.runtime.FindSupport.findInPlugin(FindSupport.java:232)
	at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:99)
	at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:60)
	at org.eclipse.core.runtime.FileLocator.find(FileLocator.java:84)
	at org.eclipse.birt.report.designer.util.DEUtil.getDefaultLibraryHandle(DEUtil.java:3235)
	at org.eclipse.birt.report.designer.internal.ui.wizards.WizardTemplateChoicePage.getDefaultLibraryHandleFromResource(WizardTemplateChoicePage.java:1043)
	at org.eclipse.birt.report.designer.internal.ui.wizards.WizardTemplateChoicePage.createControl(WizardTemplateChoicePage.java:350)
the line of code which went wrong is:
URL url = FileLocator.find( Platform.getBundle( IResourceLocator.FRAGMENT_RESOURCE_HOST ),
				new Path( DEFAULT_LIBRARY ),
				null );
DEFAULT_LIBRARY is defined like this:
	public static final String DEFAULT_LIBRARY = "/ThemesReportItems.rptlibrary"; //$NON-NLS-1$
i searched the whole repo, but i can't find a file ThemesReportItems.rptlibrary there. what am i missing?
Consequence of this is an empty wizardpage showing up, so i can't create an emtpy / new report.
thx in advance,
hag
[Updated on: Tue, 20 March 2012 08:48]
Report message to a moderator
Re: Building the designer, Nullpointer in DEUtil.java [message #824987 is a reply to message #824922] Tue, 20 March 2012 10:22 Go to previous messageGo to next message
Member
hm, solved it by comparing the plugins folder of the downloadable win version of the designer with the one in my targetplatform and adding all missing plugins to it
(but still don't know where i can find that rptlibrary file. anyway, don't need it anymore)
Re: Building the designer, Nullpointer in DEUtil.java [message #1077593 is a reply to message #824987] Thu, 01 August 2013 23:08 Go to previous message
Jesse Weinstein is currently offline Jesse WeinsteinFriend
Member
Thanks, your suggestion solved it for me, too. The only plugins I needed to add were all the org.eclipse.birt ones (and their non-optional dependencies). I've listed the full list below, for reference (this is with BIRT 4.2.2). It would be nice if someone would figure out why the default list is insufficient.
<plugin id="com.ibm.icu"/>
<plugin id="com.lowagie.text"/>
<plugin id="javax.annotation"/>
<plugin id="javax.el"/>
<plugin id="javax.inject"/>
<plugin id="javax.servlet"/>
<plugin id="javax.servlet.jsp"/>
<plugin id="javax.wsdl"/>
<plugin id="javax.xml"/>
<plugin id="javax.xml.rpc"/>
<plugin id="javax.xml.soap"/>
<plugin id="org.apache.axis"/>
<plugin id="org.apache.batik.bridge"/>
<plugin id="org.apache.batik.css"/>
<plugin id="org.apache.batik.dom"/>
<plugin id="org.apache.batik.dom.svg"/>
<plugin id="org.apache.batik.ext.awt"/>
<plugin id="org.apache.batik.parser"/>
<plugin id="org.apache.batik.pdf"/>
<plugin id="org.apache.batik.svggen"/>
<plugin id="org.apache.batik.transcoder"/>
<plugin id="org.apache.batik.util"/>
<plugin id="org.apache.batik.util.gui"/>
<plugin id="org.apache.batik.xml"/>
<plugin id="org.apache.commons.codec"/>
<plugin id="org.apache.commons.discovery"/>
<plugin id="org.apache.commons.logging"/>
<plugin id="org.apache.derby.core"/>
<plugin id="org.apache.jasper.glassfish"/>
<plugin id="org.apache.lucene"/>
<plugin id="org.apache.lucene.analysis"/>
<plugin id="org.apache.lucene.core"/>
<plugin id="org.apache.xerces"/>
<plugin id="org.apache.xml.resolver"/>
<plugin id="org.apache.xml.serializer"/>
<plugin id="org.eclipse.birt.axis.overlay" fragment="true"/>
<plugin id="org.eclipse.birt.chart.cshelp"/>
<plugin id="org.eclipse.birt.chart.device.extension"/>
<plugin id="org.eclipse.birt.chart.device.pdf"/>
<plugin id="org.eclipse.birt.chart.device.svg"/>
<plugin id="org.eclipse.birt.chart.device.swt"/>
<plugin id="org.eclipse.birt.chart.engine"/>
<plugin id="org.eclipse.birt.chart.engine.extension"/>
<plugin id="org.eclipse.birt.chart.examples"/>
<plugin id="org.eclipse.birt.chart.examples.core"/>
<plugin id="org.eclipse.birt.chart.reportitem"/>
<plugin id="org.eclipse.birt.chart.reportitem.ui"/>
<plugin id="org.eclipse.birt.chart.ui"/>
<plugin id="org.eclipse.birt.chart.ui.extension"/>
<plugin id="org.eclipse.birt.core"/>
<plugin id="org.eclipse.birt.core.script.function"/>
<plugin id="org.eclipse.birt.core.ui"/>
<plugin id="org.eclipse.birt.cshelp"/>
<plugin id="org.eclipse.birt.data"/>
<plugin id="org.eclipse.birt.data.aggregation"/>
<plugin id="org.eclipse.birt.doc"/>
<plugin id="org.eclipse.birt.example"/>
<plugin id="org.eclipse.birt.jetty.overlay" fragment="true"/>
<plugin id="org.eclipse.birt.me.prettyprint.hector"/>
<plugin id="org.eclipse.birt.report.data.adapter"/>
<plugin id="org.eclipse.birt.report.data.bidi.utils"/>
<plugin id="org.eclipse.birt.report.data.bidi.utils.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.excel"/>
<plugin id="org.eclipse.birt.report.data.oda.excel.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.hive"/>
<plugin id="org.eclipse.birt.report.data.oda.hive.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.jdbc"/>
<plugin id="org.eclipse.birt.report.data.oda.jdbc.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.sampledb"/>
<plugin id="org.eclipse.birt.report.data.oda.sampledb.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.xml"/>
<plugin id="org.eclipse.birt.report.data.oda.xml.ui"/>
<plugin id="org.eclipse.birt.report.designer.core"/>
<plugin id="org.eclipse.birt.report.designer.samplereports"/>
<plugin id="org.eclipse.birt.report.designer.ui"/>
<plugin id="org.eclipse.birt.report.designer.ui.cubebuilder"/>
<plugin id="org.eclipse.birt.report.designer.ui.data"/>
<plugin id="org.eclipse.birt.report.designer.ui.editors"/>
<plugin id="org.eclipse.birt.report.designer.ui.editors.schematic"/>
<plugin id="org.eclipse.birt.report.designer.ui.lib"/>
<plugin id="org.eclipse.birt.report.designer.ui.lib.explorer"/>
<plugin id="org.eclipse.birt.report.designer.ui.preview.web"/>
<plugin id="org.eclipse.birt.report.designer.ui.rcp"/>
<plugin id="org.eclipse.birt.report.designer.ui.samples.rcp"/>
<plugin id="org.eclipse.birt.report.designer.ui.samplesview"/>
<plugin id="org.eclipse.birt.report.designer.ui.views"/>
<plugin id="org.eclipse.birt.report.engine"/>
<plugin id="org.eclipse.birt.report.engine.dataextraction"/>
<plugin id="org.eclipse.birt.report.engine.dataextraction.csv"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.excel"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.html"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.odp"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.ods"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.odt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.pdf"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.postscript"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.ppt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.wpml"/>
<plugin id="org.eclipse.birt.report.engine.emitter.html"/>
<plugin id="org.eclipse.birt.report.engine.emitter.odp"/>
<plugin id="org.eclipse.birt.report.engine.emitter.ods"/>
<plugin id="org.eclipse.birt.report.engine.emitter.odt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.pdf"/>
<plugin id="org.eclipse.birt.report.engine.emitter.postscript"/>
<plugin id="org.eclipse.birt.report.engine.emitter.ppt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.prototype.excel"/>
<plugin id="org.eclipse.birt.report.engine.emitter.wpml"/>
<plugin id="org.eclipse.birt.report.engine.fonts"/>
<plugin id="org.eclipse.birt.report.engine.odf"/>
<plugin id="org.eclipse.birt.report.engine.script.javascript"/>
<plugin id="org.eclipse.birt.report.item.crosstab.core"/>
<plugin id="org.eclipse.birt.report.item.crosstab.ui"/>
<plugin id="org.eclipse.birt.report.model"/>
<plugin id="org.eclipse.birt.report.model.adapter.oda"/>
<plugin id="org.eclipse.birt.report.viewer"/>
<plugin id="org.eclipse.birt.resources"/>
<plugin id="org.eclipse.compare.core"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filebuffers"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry" fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.datatools.connectivity"/>
<plugin id="org.eclipse.datatools.connectivity.oda"/>
<plugin id="org.eclipse.datatools.connectivity.oda.consumer"/>
<plugin id="org.eclipse.datatools.connectivity.oda.design"/>
<plugin id="org.eclipse.datatools.connectivity.oda.design.ui"/>
<plugin id="org.eclipse.datatools.connectivity.oda.profile"/>
<plugin id="org.eclipse.datatools.connectivity.sqm.core"/>
<plugin id="org.eclipse.datatools.connectivity.ui"/>
<plugin id="org.eclipse.datatools.enablement.oda.xml"/>
<plugin id="org.eclipse.datatools.enablement.oda.xml.ui"/>
<plugin id="org.eclipse.datatools.help"/>
<plugin id="org.eclipse.datatools.modelbase.dbdefinition"/>
<plugin id="org.eclipse.datatools.modelbase.sql"/>
<plugin id="org.eclipse.draw2d"/>
<plugin id="org.eclipse.e4.core.commands"/>
<plugin id="org.eclipse.e4.core.contexts"/>
<plugin id="org.eclipse.e4.core.di"/>
<plugin id="org.eclipse.e4.core.di.extensions"/>
<plugin id="org.eclipse.e4.core.services"/>
<plugin id="org.eclipse.e4.ui.bindings"/>
<plugin id="org.eclipse.e4.ui.css.core"/>
<plugin id="org.eclipse.e4.ui.css.swt"/>
<plugin id="org.eclipse.e4.ui.css.swt.theme"/>
<plugin id="org.eclipse.e4.ui.di"/>
<plugin id="org.eclipse.e4.ui.model.workbench"/>
<plugin id="org.eclipse.e4.ui.services"/>
<plugin id="org.eclipse.e4.ui.widgets"/>
<plugin id="org.eclipse.e4.ui.workbench"/>
<plugin id="org.eclipse.e4.ui.workbench.addons.swt"/>
<plugin id="org.eclipse.e4.ui.workbench.renderers.swt"/>
<plugin id="org.eclipse.e4.ui.workbench.swt"/>
<plugin id="org.eclipse.e4.ui.workbench3"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.change"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.ds"/>
<plugin id="org.eclipse.equinox.event"/>
<plugin id="org.eclipse.equinox.http.jetty"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.equinox.jsp.jasper"/>
<plugin id="org.eclipse.equinox.jsp.jasper.registry"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.util"/>
<plugin id="org.eclipse.gef"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.help.base"/>
<plugin id="org.eclipse.jetty.continuation"/>
<plugin id="org.eclipse.jetty.http"/>
<plugin id="org.eclipse.jetty.io"/>
<plugin id="org.eclipse.jetty.security"/>
<plugin id="org.eclipse.jetty.server"/>
<plugin id="org.eclipse.jetty.servlet"/>
<plugin id="org.eclipse.jetty.util"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.ltk.core.refactoring"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.cheatsheets"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.navigator"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.ui.workbench.texteditor"/>
<plugin id="org.eclipse.update.configurator"/>
<plugin id="org.mozilla.javascript"/>
<plugin id="org.w3c.css.sac"/>
<plugin id="org.w3c.dom.smil"/>
<plugin id="org.w3c.dom.svg"/>
<plugin id="org.w3c.sac"/>
Previous Topic:Render while report is generated
Next Topic:Drill Through To Cascading Parameters
Current Time: Wed Feb 21 19:30:47 GMT 2018
Powered by FUDForum. Page generated in 0.02178 seconds
