Home » Modeling » Papyrus » Generate .di2
Generate .di2 [message #824458] Mon, 19 March 2012 17:45 Go to next message
Cristina Murillo is currently offline Cristina MurilloFriend
I am trying to generate a uml model using model transformations.
My result is a .uml file. Is there a way on Papyrus that I create the .di2 file from a given .uml file (generated by another tool)?
Thank you,
Cristina
Re: Generate .di2 [message #834836 is a reply to message #824458] Mon, 02 April 2012 13:05 Go to previous messageGo to next message
Tristan Faure is currently offline Tristan FaureFriend
I think you are trying to use old Papyrus editors,
the extension of the MDT papyrus editor is "di" I think you shall try with this version.
Re: Generate .di2 [message #836185 is a reply to message #834836] Wed, 04 April 2012 07:18 Go to previous messageGo to next message
Alexandra Bardiau is currently offline Alexandra BardiauFriend
This should probably answer your question:
wiki.eclipse.org/Papyrus_User_Guide#Create_a_diagram_from_an_existing_uml_file
Cheers!
Re: Generate .di2 [message #837220 is a reply to message #836185] Thu, 05 April 2012 12:06 Go to previous messageGo to next message
Or this:
www.eclipse.org/forums/index.php/m/696191/
Re: Generate .di2 [message #865284 is a reply to message #837220] Mon, 30 April 2012 10:20 Go to previous messageGo to next message
Thank you for your reply, I was actually using an old version of Papyrus. I was able to generate the diagram from the UML file by using the latest release 0.8.2.
Thanks!!
Re: Generate .di2 [message #868098 is a reply to message #865284] Tue, 01 May 2012 16:43 Go to previous message
wiwa wiwa is currently offline wiwa wiwaFriend
I have the same problem and I'm trying to generate a Papyrus model (.di2) from an existing .uml file. But the result is always an empty model.
Can you please help me.
Thank you,
Previous Topic:Erasing a class does not remove it from Papyrus model.uml ?
Next Topic:How to synchronize a UML profiles and its client models ?
Current Time: Fri Apr 20 09:14:34 GMT 2018
Powered by FUDForum. Page generated in 0.01925 seconds
