Home » Eclipse Projects » Equinox » Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox)
Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #101382] Fri, 09 November 2007 16:38 Go to next message
Originally posted by: dp-conde.criticalsoftware.com
Once again, I'm posting here to try and find a solution to my problem. I
have a RAP application and I'm trying to get the eclipse help system to
work without problems.
So far I've managed to get the help system to work, but the problem is
that the bundle org.eclipse.help.webapp is conflicting with something,
probably from RAP or equinox. At least it must be because when I start
the org.eclipse.help.webapp to be able to use the eclipse help system,
the application simply stops loading the pictures from the application's
resources.
If I don't start org.eclipse.help.webapp, then everything works fine,
but I can't use the eclipse help system.
Anyone having the same problem, or ideas on how to solve it?
Thanks in advance,
Daniel Conde.
Re: Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #101394 is a reply to message #101382] Fri, 09 November 2007 20:12 Go to previous messageGo to next message
Simon Kaegi is currently offline Simon KaegiFriend
Hi Daniel,
Sounds to me like you may have conflicting resource registrations from
disagreement over who owns the URI space.
Help registers a resource handler at the URI root.
e.g. "/"
<extension
point="org.eclipse.equinox.http.registry.resources">
<resource
alias="/"
base-name="/"
httpcontextId="help">
</resource>
</extension>
The above snippet is from org.eclipse.help.webapp's plugin.xml.
It's quite likely that RAP also registers something at this alias.
Take a look at their plugin.xml or perhaps in their code to see where
they're registering resources and servlets.
If you want to dig deeper set up some breakpoint inside the "register*"
methods in org.eclipse.equinox.http.servlet.internal.HttpServiceImpl.
HTH
-Simon
"Daniel Conde" <dp-conde@criticalsoftware.com> wrote in message
news:fh22eg$tao$2@build.eclipse.org...
> Hello,
> probably from RAP or equinox. At least it must be because when I start the
> org.eclipse.help.webapp to be able to use the eclipse help system, the
> resources.
> If I don't start org.eclipse.help.webapp, then everything works fine, but
> Thanks in advance,
> Daniel Conde.
Re: Eclipse Help System - org.eclipse.help.webapp (conflict with RAP or equinox) [message #101484 is a reply to message #101394] Tue, 13 November 2007 09:31 Go to previous message
Hello Kaegi,
Thanks for your tip, you where right. There was a resource registration
conflict that needed to be solved, so I changed the extension point for
the webapp bundle, and it worked fine.
But having bundles changed isn't a good politic, so now, all I need is
to design a patch or something alike to change the bundle.
Thanks for your tip.
Daniel Conde.
Simon Kaegi wrote:
> Hi Daniel,
> e.g. "/"
> <extension
> <resource
> alias="/"
> base-name="/"
> </resource>
> </extension>
> HTH
> -Simon
>> Hello,
>> resources.
>> Thanks in advance,
>> Daniel Conde.
Previous Topic:Open Source Software Research
Next Topic:NoClassDefFoundError
Current Time: Mon Jun 25 06:38:11 GMT 2018
Powered by FUDForum. Page generated in 0.02141 seconds
