Home » Newcomers » Newcomers » Eclipse Plugin Development
Eclipse Plugin Development [message #101304] Mon, 12 September 2005 10:33 Go to next message
Eclipse User
Originally posted by: daniel.e.quintero.gmail.com
im working in producing a plug-in based
eclipse application, i was wondering if someone
can give me some insights in the following problems
i been having :
* Multiple Plugin Development
i have several plugins i created in my workspace
some control the upper level of functionality of
my application some provide the lower objects models.
Each set of plugins have configurations files and logging
files , some of these files are dependant of runtime so
are only dependant of relative URL to work .
when i try to use a plugin from another i get two possible
scenarios
In the first one the classpath dependant files are found
but the URL dependant files are not found.
In the second one the classpath dependant files are not found
but the URL dependans files are found.
So im wondering whats it the correct way to handle plug-in dependency
inside a workbench ???????
att
Diana villamil
Re: Eclipse Plugin Development [message #101341 is a reply to message #101304] Mon, 12 September 2005 12:38 Go to previous messageGo to next message
Eclipse User
Originally posted by: markus.nosse.gmx.net
hopefully, my comments below are of some help to you.
-- markus
Plugin dependencies can be stated in the plugin manifest (plugin.xml)
using the
<requires> tag, under which you can nest <import tags like <import
plugin="...plugin id..." />
So all your upper level plugins which depend on your lower level plugin(s)
will have to import the lower level plugin.
> scenarios
To find configuration files (which are part of the plugin installation
bundle), the getInstallURL() method of the PluginDescriptor object of your
plugin may be useful. Similarly, from the plugin object using method
getStateLocation(), you can get the plugin's state location, i.e. a folder
in the workspace.
Note that the class and method names are of Eclipse v2.1, and there have
some changes. But I am confident the concept remained the same
Re: Eclipse Plugin Development [message #101351 is a reply to message #101341] Mon, 12 September 2005 13:25 Go to previous messageGo to next message
Eclipse User
Hi ;)
Markus thanks for your help it helped me
sort out some of the problems however some of this
already persist, this is what happening
when i run a test case in the plugin it can find local files
for example plugin A depends from file A.txt and when i run a
local test case it works wonderfull.
However plugin B depends of plugin A when i run a testcase from
B it find A alright and can work with every packages A exports
but when it gets to the point where A has to look for file A.txt
A doesnt find it anymore... why does this happend ?
thanks again for your help on the first one markus
att,
Diana Villamil
Markus wrote:
> -- markus
> using the <requires> tag, under which you can nest <import tags like
> <import plugin="...plugin id..." />
> plugin(s) will have to import the lower level plugin.
>> scenarios
> your plugin may be useful. Similarly, from the plugin object using
> method getStateLocation(), you can get the plugin's state location, i.e.
> a folder in the workspace.
Re: Eclipse Plugin Development [message #101485 is a reply to message #101351] Tue, 13 September 2005 03:19 Go to previous messageGo to next message
Eclipse User
what do you mean by "run a testcase"? Do you run a JUnit test case, do you
start a run-time workbench and test your plugins in this environment? I'd
also like to know how you access your A.txt file, do you open it as a
java.io.File, an eclipse IFile or do you use a classloader to get the file
as a resource (like ClassLoader.getResourceAsStream()).
In the latter case, be sure to use the correct classloader. As you may
know, each plugin has its dedicated classloader which you can obtain from
the plugin descriptor.
Another thing to consider is what you include in the binary distribution
of your plugin, but I think that is not your current concern. Still, you
may take a look at the build.properties file of your plugins to learn mor
about plugin packaging.
-- Markus
Daniel wrote:
> Hi ;)
> att,
> Diana Villamil
Re: Eclipse Plugin Development [message #102489 is a reply to message #101485] Fri, 16 September 2005 11:25 Go to previous message
Eclipse User
Thanks for you all your concern for circunstances out of my control
i have to leave the integration of my plugins aside for a while
meanwhile i fix some functionality concerns first.
However i am deeply thankfull for you all help
att,
Diana Villamil
Markus wrote:
> you start a run-time workbench and test your plugins in this
> environment? I'd also like to know how you access your A.txt file, do
> you open it as a java.io.File, an eclipse IFile or do you use a
> classloader to get the file as a resource (like
> from the plugin descriptor.
> mor about plugin packaging.
> -- Markus
> Daniel wrote:
>> Hi ;)
>> att,
>> Diana Villamil
Previous Topic:global search
Next Topic:Problem starting 3.1 on Win2000 and VM1.5
Current Time: Tue May 21 21:30:55 EDT 2013
Powered by FUDForum. Page generated in 0.01536 seconds
