Home » Eclipse Projects » P2 » Processing of installation export file (p2f)?
Processing of installation export file (p2f)? [message #820774] Wed, 14 March 2012 10:52 Go to next message
Stephan Herrmann is currently offline Stephan Herrmann
I'm experimenting with the export capability added in 3.7 that creates a p2f file from the currently installed set of features.
This looks very promising!
Side note: The access to meta data from the various repositories is painfully slow, I just waited approx. 15 min. for the answer "Cannot statisfy dependency: ...". From looking at the p2f file repositories are listed multiply over and over, so maybe downloading the same meta data over and over again explains the long wait, but that's a side issue.
Right now I'm curious, whether any of the other tools can take a p2f file as their input. I think the following would be totally cool:
- create a feature from a p2f
- extract features and repository URLs into a contribution for the b3aggregator
Et voila: you have a mirrored update site with all those features that you have prototypically installed in your IDE.
Has anyone thought about this / worked on this already?
best,
Stephan
Re: Processing of installation export file (p2f)? [message #822449 is a reply to message #820774] Fri, 16 March 2012 12:38 Go to previous message
Pascal Rapicault is currently offline Pascal Rapicault
These are indeed cool enhancements. You should definitely file a bug so those are not lost.
At this the enhancements we discussed around p2f are:
- have the director take p2f
- extend the p2f to describe a complete install
Pascal
Consulting and training - pascal (at) rapicault.net
Previous Topic:bundles.info can not be updated after install new plugin?
Next Topic:Character corruption in the content.xml
Current Time: Thu May 23 16:51:03 EDT 2013
Powered by FUDForum. Page generated in 0.01749 seconds
