Home » Eclipse Projects » Nebula » Pagination for data coming from a OSGi Persistence Service
Pagination for data coming from a OSGi Persistence Service [message #820393] Wed, 14 March 2012 00:10 Go to next message
Cristiano Gaviao is currently offline Cristiano Gaviao
Currently I have a persistence bundle (using gemini JPA + eclipselink) that exposes some business data services. Basically the methods of those services returns collection of entity pojos.
what would be the best approach to use the pagination widget for presenting data from my persistence service?
should I modify the query methods somehow to return just a number of entities at time?
cheers,
Cristiano
Re: Pagination for data coming from a OSGi Persistence Service [message #825187 is a reply to message #820393] Tue, 20 March 2012 11:26 Go to previous message
Angelo ZERR is currently offline Angelo ZERR
Hi Christiano,
We uses Nebula Pagination Control in our Eclipse RCP/RAP XDocReport http://xdocreport-rap.opensagres.cloudbees.net/xdocreport?startup=fr.opensagres.xdocreport.eclipse.ui.application (and you can browse source at http://code.google.com/p/xdocreport/source/browse/?repo=eclipse)
We uses Eclipse Gemini Blueprint, EclipseLink, JPA but with Spring Data, which is very very impressive (no need to code your JPA Query for CRUD). So I suggest you to use it.
Nebula Pagination Control provides the capability to paginate by using ResultPage structure, but it's extensible and we have created an extension to works with Spring Data Structure (Pageable, Page) (see http://code.google.com/p/xdocreport/source/browse/?repo=eclipse#git%2Fcommons%2Forg.eclipse.nebula.widgets.pagination.springdata)
We have an abstract class SearchDialog http://code.google.com/p/xdocreport/source/browse/commons/fr.opensagres.xdocreport.eclipse.ui/src/fr/opensagres/xdocreport/eclipse/ui/dialogs/SearchDialog.java?repo=eclipse which implements org.eclipse.nebula.widgets.pagination.springdata.ISpringDataPageLoader
(See the code in this classto create the Pagination Control with Spring Data).
Here an example of implementation of SearchDialog http://code.google.com/p/xdocreport/source/browse/dynaresume/org.dynaresume.eclipse.search.ui/src/org/dynaresume/eclipse/search/ui/dialogs/SearchResumeDialog.java?repo=eclipse
public Page<Resume> loadPage(PageableController controller) {
  return resumeService.findByFirstNameAndLastName(firstNameCriteria, lastNameCriteria, (Pageable) controller);
This method implements ISpringDataPageLoader to load paginated data with Spring Data.
Hope my explanation will help you.
Regards Angelo
Previous Topic:Center text in GridColumnGroup
Next Topic:CalendarCombo: how can I open the calendar with another month then the actual month?
Current Time: Tue Jun 18 19:18:10 EDT 2013
Powered by FUDForum. Page generated in 0.01501 seconds
