Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] Deadlocks when using with transactional editing domains
[EEF] Deadlocks when using with transactional editing domains [message #819993] Tue, 13 March 2012 15:37 Go to next message
Jan Mauersberger is currently offline Jan MauersbergerFriend
we are using EEF 1.0.2 for Indigo with resource sets that have
transactional editing domains. There is code in the base class
SinglePartPropertiesEditingComponent#initializeSemanticAdapter (or more
precisely in PropertiesEditingSemanticLister#notifyChanged that is doing
a thread switch to the UI thread regardless of the kind of notification.
However, in some cases we are facing deadlocks, e.g. in case the adapter
is removed, due to several other side constraints.
Is it possible to make this code more smart or flexible or at least
easier for custom base classes to intercept such synchronized calls to
the UI thread?
Thanks in advance
Jan
Re: [EEF] Deadlocks when using with transactional editing domains [message #821583 is a reply to message #819993] Thu, 15 March 2012 14:59 Go to previous messageGo to next message
Stephane Bouchet is currently offline Stephane BouchetFriend
Hi Jan,
The notifyChanged Method can be extended by the generated classes in
order to meet your needs.
We use EEF in transactional editing domains, too, and did not notify
somes glitches.
Can you provide a test case in Bugzilla ?
thanks,
Le 13/03/2012 16:37, Jan Mauersberger a écrit :
> the UI thread?
> Thanks in advance
> Jan
Stéphane Bouchet, OBEO
Re: [EEF] Deadlocks when using with transactional editing domains [message #822391 is a reply to message #821583] Fri, 16 March 2012 14:54 Go to previous messageGo to next message
Hi Stephane,
thanks for your reply. Could you please give me some hint how to
customize the code best? The problematic code is located in
PropertiesEditingSemanticLister#notifyChanged as you probably was
referring to. However, the instance of this class is created as
anonymous sub-class in
StandardPropertiesEditionComponent#initializeSemanticAdapter as
protected PropertiesEditingSemanticLister initializeSemanticAdapter() {
return new PropertiesEditingSemanticLister(this) {
public void runUpdateRunnable(Notification msg) {
updatePart(msg);
That forces us currently to derive from
SinglePartPropertiesEditingComponent and overwrite
initializeSemanticAdapter. Any other (better) way to do it?
I do not have a reproducible scenario at least not to easily write a
test case. I also do not say that this is a bug of EEF or similar.
However, at this point in time, the UI thread is blocked and locked
already, executing a sync operation is not possible in our scenario so I
need some flexibility and customization here.
Cheers Jan
> Hi Jan,
> somes glitches.
> thanks,
>> the UI thread?
>> Thanks in advance
>> Jan
Re: [EEF] Deadlocks when using with transactional editing domains [message #830380 is a reply to message #822391] Tue, 27 March 2012 14:53 Go to previous message
hi jan,
Le 16/03/2012 15:54, Jan Mauersberger a écrit :
> Hi Stephane,
> updatePart(msg);
no, this is what i suggested to you. this is the good way to modify this
specific part of the EEF runtime.
please note that you can use the LeafComponentsSuperClass property on
the eefgen model ( Gen Edition Context object ) to override on each
component of your model.
i can easily understand your customization needs :) we tried to open the
API to be able to override the Runtime easily, so feel free to open a
request on bugzilla if you want more API customization.
> Cheers Jan
>> Hi Jan,
>> somes glitches.
>> thanks,
>>> Hi,
>>> the UI thread?
>>> Thanks in advance
>>> Jan
Previous Topic:[EEF] EEFTreeMasterPart default adapterFactory with AdapterFactoryEditingDomain
Next Topic:[EEF] Unexpected behavior when properties view is pinned
Current Time: Thu Jan 18 21:29:36 GMT 2018
Powered by FUDForum. Page generated in 0.01638 seconds
