Home » Language IDEs » C / C++ IDE (CDT) » C/C++ MinGW debug problem(Can't find a source file at "../mingw/crt1.c")
C/C++ MinGW debug problem [message #819007] Mon, 12 March 2012 11:18 Go to next message
Stefan Wissenbach is currently offline Stefan WissenbachFriend
Hi all,
I'm using Windows XP SP3, Eclipse Indigo Service Release 1, MinGW gcc 4.6.2 and
MySQLConnectorC for a simple Database Connection.
It builds fine and I can run it from console, also Debugging with gdb is no problem.
The issue is Eclipse, when I run the code the console shows
<terminated>Test.exe[C/C++ Application]
In the debug mode everithing is normal, the connection is established and all
outputs are shown in the console but at the end there is
__mingw_CRTStartup() at .../mingw/crt1.c:250 0x4010bb
Locate the file or edit the source lookup path to include its location.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <windows.h>
#include <mysql.h>
int main() {
	MYSQL *conn;
	MYSQL_RES *res;
	MYSQL_ROW row;
	char *server = "localhost";
	char *user = "root";
	char *password = ""; /* set me first */
	char *database = "systemsimulation";
	conn = mysql_init(NULL);
	/* Connect to database */
	if (!mysql_real_connect(conn, server, user, password, database, 0, NULL,
			0)) {
		fprintf(stderr, "%s\n", mysql_error(conn));
	/* send SQL query */
	if (mysql_query(conn, "show tables")) {
	res = mysql_use_result(conn);
	/* output table name */
	printf("MySQL Tables in mysql database:\n");
	while ((row = mysql_fetch_row(res)) != NULL)
		printf("%s \n", row[0]);
	/* close connection */
	mysql_free_result(res);
	mysql_close(conn);
	return EXIT_SUCCESS;
Any suggestions for this problem?
Re: C/C++ MinGW debug problem [message #819731 is a reply to message #819007] Tue, 13 March 2012 09:04 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
You can safely ignore this message.
I guess during debug you stepped through the whole code until the last line. When your code is finished (i.e. your main() routine) it will return to the system function that actually started your code. In your case this is __mingw_CRTStartup().
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:iostream not recognized
Next Topic:libxml2
Current Time: Wed Feb 21 12:01:09 GMT 2018
Powered by FUDForum. Page generated in 0.01853 seconds
